Thread: Eddie's table modifier
Results 1 to 11 of 11
  1. #1 Eddie's table modifier
    Buffalo
    just to show - its super simple, effective and works so I been using this since 08 and everyone still ****s on it and ****s on maf tuning so im just gonna post the text file to show the changes
    i kept the stock maf file for a N* v8 truck given from a member here
    I had "decent" trims but i was not getting my MPG that I was used to
    one cruise , one file transfer into the program, loaded it back to my ecu and well im locking +/- 2 while cruising now and my MPGs are back into the 30s
    edit cant upload a 15kb text file?
  2. #2 Re: Eddie's table modifier
    Buffalo
    edit cant paste the document here without it distorting the data columns Scotty? can u figure it out ?
  3. #3 Re: Eddie's table modifier
    Buffalo
  4. #4 Re: Eddie's table modifier
    take a screen shot, save as jpeg and host on pb.
  5. #5 Re: Eddie's table modifier
    Buffalo
    Blah. I posted the log. You can see the changes and filters. Super simple Y'all gotta get on it
  6. #6 Re: Eddie's table modifier
    ive used eddies, i also stopped using eddies lol
  7. #7 Re: Eddie's table modifier
    Quote Originally Posted by CrazyGuy03 View Post
    whats odd is it added fuel to the maf in the idle to cruise range, idle, 1000-3000 maf hertz, cruise 3000-7000 , 7000 up wot.
  8. #8 Re: Eddie's table modifier
    Buffalo
    I guess back when I started , it was this or spreadsheets and math. I learned this way. And for as long as I had the s1x cam - I only tuned my car once.
    So getting back into it again , it was just as easy as I remembered.
    Now I was getting +16.4 at idle and on de-accel on the thruway. So I wanted to try to get my trims back to normal from idle to about 7k on the maf
    who knows if the s3 cam has anything to do with some
    of my off readings. I know I need to run around 30* at idle to keep the car from "hunting"
  9. #9 Re: Eddie's table modifier
    GXP Level Member
    Mar 2015
    Tomball
    I've used it. It seems to work when the tune is off a good bit like when I used the stock MAF table then used it after logging then it was better then used it a second time and it was a little better, but it seems after the second time it wants to over shoot or under shoot. It's great for getting close the. I just modify the table manually after that.
  10. #10 Re: Eddie's table modifier
    Buffalo
    Knowing how to use those filters is key
    i just wish more people would see it as helpful then not
  11. #11 Re: Eddie's table modifier
    hangover park IL
    It really does help to filter out decell FTC unless you further limit it to your idle and Below maf frequencies.
    I <3 thingy
    ~James~ Psychotic Gearhead
  1. Eddie's table modifier
    By CrazyGuy03 in forum PCM Tuning
    Last Post: 09-02-2016, 11:42 PM
  2. F/S: Eddie's Garage Cleanout- Everything Must Go!!
    By gtpeddie in forum For Sale - Parts
    Last Post: 03-28-2014, 03:18 PM
  3. Eddie's Table Modifier
    By Nighthwk12 in forum PCM Tuning
    Last Post: 07-18-2013, 09:21 AM
  4. UV Scan and The Table Modifier Thingy
    By LapeerGTP in forum PCM Tuning
    Last Post: 08-10-2012, 02:35 PM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
