Thread: Ipw at idle
Results 1 to 5 of 5
  1. #1 Ipw at idle
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Im trying to diagnose an issue im having. What is your IPW at idle? I just changed to some 95# injectors and the ltfts are dumping fuel like crazy. My wideband says 22 to 1 but my IPW is 2.5 so it really shouldnt be lean. Yes i know i have a vac leak somewhere im just having a hell of a time finding it...it doesnt idle up with starting fluid like i would expect it to.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: Ipw at idle
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Also the o2 sensor is holding steady below 200mV
  3. #3 Re: Ipw at idle
    Omaha, NE
    I would check the injectors and make sure that the connections are solid.
  4. #4 Re: Ipw at idle
    in TT theres a setting for injector voltage vs something. it might help you out. another guy here is running 80's on corn and found this fix.
    toss 40thAnnGTP2002 a pm. he knows better what he changed. has some thing to do with the injectors just being way to large for the pcm to deal with having the stock settings there.
  5. #5 Re: Ipw at idle
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I just changed the connectors so i know they are good. Wondering if i broke or cut a wire in the harness when i had it all apart...
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. Intermittent Idle Surge/Rough Idle
    By 99coupegtp in forum General Grand Prix Discussion
    Last Post: 07-31-2016, 05:11 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
