Thread: DHP to USB?
Results 1 to 12 of 12
  1. #1 DHP to USB?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Can the dhp box be converted to USB and basically bypass the keyspan serial adapter?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: DHP to USB?
    Kemmerer, Wyoming
    it can, but I think you have to get the box already formatted in that way from the avt people
  3. #3 Re: DHP to USB?
    iirc bill posted the wires to a usb inside a dhp.
  4. #4 Re: DHP to USB?
    GXP Level Member
    Mar 2015
    Tomball
    What the hell is keyspan? Most people call them USB to RS-232 adapters. Is there something special about these?
    Jeff
  5. #5 Re: DHP to USB?
    Kemmerer, Wyoming
    keyspan is just the company that made the cables. from what I've heard, other makers were less reliable, so people opted for the big name. at this point, any rs-232 should work just fine, as far as I know.
  6. #6 Re: DHP to USB?
    GXP Level Member
    Mar 2015
    Tomball
    Ok, makes sense they are kind of like the cheap ELM327's hit or miss. We used to buy tons of these for work and we would get a bad batch from one place or another. Didn't even know keyspan was a company. Lol
    Jeff
  7. #7 Re: DHP to USB?
    keyspan is a brand of serial to usb that seems to work best.
  8. #8 Re: DHP to USB?
    Apr 2014
    South Haven, MI
    It would be nice to speed up full writes and reading the pcm. Any idea on how bill did it?
  9. #9 Re: DHP to USB?
    pm him. hes not on a lot no more and may not ever see this thread.
  10. #10 Re: DHP to USB?
    GXP Level Member
    Mar 2015
    Tomball
    Unless the USB driver is already installed into the hardware then it's not possible to go from USB to RS-232. I deal with a lot of serial interfaces RS-232, 422, 485 and in order to go to any of those you have to have the hardware to interface to USB. If you can take a pic of th box open top and bottom I can tell you.
    Jeff
  11. #11 Re: DHP to USB?
    Apr 2014
    South Haven, MI
    Im just going to sell my DHP and get an AVT 852.
  12. #12 Re: DHP to USB?
    Jul 2013
    UNITED STATES
    Sorry for a late response. But I am the one who did do the conversion to USB on my dhp box. There are pictures on the dropbox link on how to do that. It makes it alot faster and reliable, haven't bricked or failed a flash since converting. What your doing is by passing the old rs232 chip inside and hooking an USB ftdi chip in its place and running at 115,200. Also stops the major problem with ground loop in the interface. 😉
