Thread: dhp VIN change not taking.
Results 1 to 4 of 4
  1. #1 dhp VIN change not taking.
    Donating Users timboku's Avatar
    Montgomery, IL
    Ok, trying something not sure it will work. Have a buddy swapping a l67 into a 2000 monte carlo. I did a tune to get all the l67 stuff onto a L36 bin from a monte. It all worked but I cannot change the vin on the pcm I am trying to flash. PCM is from a GP so not sure if that is the issue it maybe. I changed the VIN in TT and it shows up in the file. But when I flash it, it still shows up with the PCM vin. VIN changing in DHP does not take either, Using VIN from File does not work either. Also, used HEX editor to change the serial from the GP PCM and VIN to the monte no luck when flashing... Trying to save time and not have me send me his PCM but may just have to. Montes need the VIN in the PCM to match the BCM for security so this is needed. I also had a spare 99 Monte PCM I tried same thing. Not to familiar with montes so probably just need his PCM to flash but any insight will be helpful.
    Thanks!
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: dhp VIN change not taking.
    if your working with the cars original pcm the vin should keep stored in the pcm. if using another pcm to tune on the new vin wont take if its the same as them 01 up gp pcm's
    not sure what pcm part # your using, but the 01 up's have a issue where you just cant change it. you'll end up bricking the pcm if you try long enough.
    the cars na pcm will work if your not using it. and the cars vin is stored in it, use use pcm vin when flashing. left side drop box in the flash window.
  3. #3 Re: dhp VIN change not taking.
    Montgomery, IL
    Thanks ya I know using his na pcm would be the best..I have a few pcms laying around was just trying to save postage one way lol..no biggie...I tried a 01 gp pcm and a 99 monte Carlo pcm I had sitting around..neither would change them anyway I tried..he will just send me the NA and call it a day.
    Sent from my SM-N910V using Tapatalk
  4. #4 Re: dhp VIN change not taking.
    yup, best way unless you can get to a tech 2, but they all want money to even open the box for it lol
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
