Thread: .HPT to BIN
Results 41 to 60 of 71
  1. #41 Re: .HPT to BIN
    flash it then as is, dont add your tune to it.
    then read it with the new 3.0 software, it should be able to be worked on then for sure id think.
    once that file is changed its changed forever so once its flashed, and re read, its there already changed forever.
  2. #42 Re: .HPT to BIN
    Kemmerer, Wyoming
    I wonder if TT will open it if the new hpt 3.2 is used to download the tune
  3. #43 Re: .HPT to BIN
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Thats what I was thinking too, I tried that and 1. car wont even start with the tune 2. I cant open it with 3.0 3. had to rewrite it with my old tune just for it to start.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #44 Re: .HPT to BIN
    Nebraska
    Quote Originally Posted by SgtMarshal View Post
    It wont since 3.2 (i think 2.2 and up) doesnt read .bin and TT doesnt read .hpt files.
  5. #45 Re: .HPT to BIN
    cant frigging win here.
  6. #46 Re: .HPT to BIN
    Nebraska
    Im going to try to start over again with stock bin and change serial and vin, hopefully I just fat fingered somewhere. Even tho I dont understand why the older HPT would still open it. Taking any suggestions lol
  7. #47 Re: .HPT to BIN
    if theres a older version of htp in db try that one out. flash with that bin, if the car fires up it should read with the newest hp format.
  8. #48 Re: .HPT to BIN
    Nebraska
    It has something to do with tinytuner modifying the file. I rewrote the vin and serial tried a file with the cat tuning on and one where i didn't touch with tiny tuner. The stock file i rewrote and converted from bin to hpt loads just fine in 3.2 where the identical file with cat testing off throws this error. Making less and less sense as I go....
  9. #49 Re: .HPT to BIN
    when you save it in tt you "save as" and name it and it saves a new file for you right? thats how i do it.
  10. #50 Re: .HPT to BIN
    for fun, why i dont i send you a bin file. and try mine, maybe it has something to do with it being opened in dhp again that fixes the checksum issue.
  11. #51 Re: .HPT to BIN
    Nebraska
    Yes thats the same way I save it. Sure ill try anything at this point.
  12. #52 Re: .HPT to BIN
    Nebraska
    Another thing I dont understand, when I changed the value of the checksum in TT it always reverted to something that looked like "7.793448E+08" when first opened the value is "255". Im pretty HPT will not work from a bin/hpt that has already been altered by other software and this checksum in TT is its way of knowing. Or at least the updated HTP
  13. #53 Re: .HPT to BIN
    Quote Originally Posted by 94GrandPrixSE View Post
    pm me your email and osid #. ill get it righ tover to ya. i got the two i listed on hand already, there might be more in the db.
  14. #54 Re: .HPT to BIN
    Nebraska
    sent
  15. #55 Re: .HPT to BIN
    Nebraska
    GTP for sale... lol
  16. #56 Re: .HPT to BIN
    Nebraska
    Tried again today, same results but I found after I flash the new bin to the pcm durring the no start condition im throwing a P0601 code - P0601 Chevrolet
    P0601 CHEVROLET - Power Control Module Internal Fault
    Anyone else ever ran into this problem?
    Read more at: http://www.engine-codes.com/p0601_chevrolet.html
    Internal Control Module Memory Check Sum Error
    Read more at: http://www.obd-codes.com/p0601
    Copyright OBD-Codes.com
  17. #57 Re: .HPT to BIN
    It might be bricked.
  18. #58 Re: .HPT to BIN
    brick aroo.
    pretty sure i got a 02 pcm sitting here. if you email me one of the bins with the vin changed i can see if dhp will flash it and keep the vin right.
    ill let it go pretty cheap too. seems no one wants a 01-02 pcm these days lol
  19. #59 Re: .HPT to BIN
    Nebraska
    If I flash it with my old tune, one I didnt touch with TT it fires right up and no P0601. That still mean it could be bricked? I thought thats for non recoverable pcms.
  20. #60 Re: .HPT to BIN
    its a checksum error, so maybe it just dont like the tt bin being flashed.
    if it started up with no cel. id think your good to go still.
    if it comes to it, i got this pcm here. i can kill the cat test, try to get it to take your vin right, 01 up seem to fight a vin change, but if the bin has the right vin it should take fine.
    once you got it you read it with htp and you have your new file to work on in hpt.
