Thread: P0171 on E85
Results 1 to 20 of 27
  1. #1 P0171 on E85
    SE Level Member MM06GT's Avatar
    Jan 2013
    SF Bay Area
    I just recently switched over to E85 and the car seems to like it except for the cold starts and the lean code. I know I need a tune but, the shop I had planned on doing the tune now says they don't do tunes anymore. The question I have, do you guys think the mini AFR controller that ZZP sells will work to richen up the fuel until I can find someone to do a tune?
    Silver 06 GrandPrix GT: K&N cai//3" catless DP//SS plog//Rear ported Mani//AL xp 104s//180* TS//ZZP 10.5 wires//TB HS//ZZP 3.2" MPS//E85//50lb injectors//1.9 YT rr//90lb sprs//Impala DP brakes//AF scan gauge//Mini AFR//BLK 18x9 saleen replicas//Overkilled.
  2. #2 Re: P0171 on E85
    Are you running e85 on a stock tune???
  3. #3 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Quote Originally Posted by gtpsleeper View Post
    No, I have an Overkill tune, but not for the E85.
  4. #4 Re: P0171 on E85
    time to buy a tuner and learn how to tune. dhp interface rns like 250, you use tiny tuner to fix the cold start issue.
    you also need to change injectors if you have not changed them yet.
  5. #5 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    I think your right Scotty, time to buy a tuner, I haven't been able to find anyone in the San Francisco bay area that tunes 3800s. Does DHP support 06 GPs? Oh and yes, I swapped in Overkills 50lb injectors.
  6. #6 Re: P0171 on E85
    Kemmerer, Wyoming
    a mini afc controller gives you higher ranges in your maf table, so the computer can function when the maf sensor is maxed out. all it really does is shift the table so the pcm sees airflow at a higher range. I don't think it will solve your lean fuel condition.
  7. #7 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Quote Originally Posted by SgtMarshal View Post
    Yeah, I have the mini afr plugged in now. It's changed my short term fuel trims a little bit, but not enough to chage the p0171 code without runnig too rich.
  8. #8 Re: P0171 on E85
    I highly suggest not running E85 if you have no tune for it.
    Not only is the cold start and lean codes a issue but it should still require up to almost 30% more fuel than regular gas when you want to make power. That could spell disaster and something could go wrong if not tuned for it.
  9. #9 Re: P0171 on E85
    didnt see the 06 part. support ended in 05 for gp's for dhp. cant you guys use a 05 pcm and run it that way?
    other option is hp tuners. costs more but is still a live co. with great support.
  10. #10 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Well, it looks like my tax return might finance hp tuners for me lol.
  11. #11 Re: P0171 on E85
    look for a used one. they pop up time to time. you can find em on ebay as well used.
    may want to get a wideband gauge too. if your tuning, its best to have one, this way you can see a real true value of your a/f ratio.
  12. #12 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Ok, will do. What wide band would you recommend?
  13. #13 Re: P0171 on E85
    Kemmerer, Wyoming
    I'd rather have it run too rich than too lean. Get the wide band that will work with the hp tuner. I recommend the pro version of hp tuner
  14. #14 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Well guys I'm back. The car is still running lean, but I did recently buy HPTuners from Overkill Motor Sports. So thing is I need a little help in which direction to tune. I read, "The defacto guide to tuning your car to e85", but I'm a little lost because I'm a newb to tuning. I think my version of HPTuners (I have what I believe to be 2.24 2013 version of HPTuners) is different because I can't seem to find, "injector gain vs cylinder" to use the method #4 in HPTuners. Forgive my newbness, this is all brand new to me and I just don't want to blow up my car lol. Are there any other threads out there that I missed or can any one help me in learning to tune for e85?
  15. #15 Re: P0171 on E85
    Kemmerer, Wyoming
    Quote Originally Posted by MM06GT View Post
    did you try emailing Will at Overkill for some help?
  16. #16 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Yeah I did with a couple of emails, but with no response.
  17. #17 Re: P0171 on E85
    Mar 2014
    Tucson
    Engine>Fuel>General> Gain vs. Cylinder.
  18. #18 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Thanks, but this is what I got: engine>fuel>general but "no start up correction". I have the standard version, could that be the reason why?
  19. #19 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    P0171 on E85 Attached Images
  20. #20 Re: P0171 on E85
    Jan 2013
    SF Bay Area
    Am I missing something?
  1. P0171
    By K Kraziee in forum General Tech Discussion
    Last Post: 06-18-2014, 11:49 AM
  2. p0171 help
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2013, 11:42 AM
  3. P0171 help please
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 02:21 AM
  4. p0171 help
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2012, 08:07 AM
  5. p0171
    By sca555 in forum General Tech Discussion
    Last Post: 04-03-2011, 02:37 PM
