Thread: using a mini afc when the maf is maxed
Results 1 to 10 of 10
  1. #1 using a mini afc when the maf is maxed
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I may have done this right but I want to make sure before I upload it to the car.
    From what I understand, the formula is 100/whatever value then multiply the result by itself twice. So 90% on the afc means I'd multiply the maf table by 1.372.
    My question is, would I just go to the maf table in DHP and set it at 137.2%?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: using a mini afc when the maf is maxed
    Kemmerer, Wyoming
    I don't think that is right, you are going to have different values in each different cell of the maf table. I'm not sure exactly how to do it, but you have to have a maf curve and not a flat line like you would get if you entered 137.2% in every cell
  3. #3 Re: using a mini afc when the maf is maxed
    Apr 2014
    South Haven, MI
    It still would be a curve. If all the values are multiplied evenly then the curve that was there before would stay. The numbers would just be 137.2% higher.
  4. #4 Re: using a mini afc when the maf is maxed
    I break stuff selliott's Avatar
    Kansas City
    I have to do this myself so I am curious as well
  5. #5 Re: using a mini afc when the maf is maxed
    Kemmerer, Wyoming
    I've read the instructions a few times now and still get confused. You might be right boosted, I probably misunderstood what you said.
  6. #6 Re: using a mini afc when the maf is maxed
    Kansas City
    If it makes you feel any better Dave (tep) stood right in front of me and explained how to use it and I still have no idea. Of course we had a couple cocktails by then lol
  7. #7 Re: using a mini afc when the maf is maxed
    Apr 2014
    South Haven, MI
    My biggest issue is the numbers towards 11500 hertz. They are passed the max value allowed by dhp
  8. #8 Re: using a mini afc when the maf is maxed
    Kansas City
    Quote Originally Posted by BoostedPontiac View Post
    I'm pretty sure that dave said there is a setting to fix that.
  9. #9 Re: using a mini afc when the maf is maxed
    Apr 2014
    South Haven, MI
    I'll have to shoot him an email then
  10. #10 Re: using a mini afc when the maf is maxed
    May 2008
    Schuyler, NE
    http://www.grandprixforums.net/threa...-HP-guys-do-it
    That should help you out with your maf table.
  1. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2019, 01:38 AM
  2. maxed out Trip Odometer
    By tod1d in forum 04+ Specifics
    Last Post: 12-12-2014, 09:35 AM
  3. Maxed out maf table at 67lbs?!?!
    By Frosty in forum PCM Tuning
    Last Post: 08-01-2013, 12:12 AM
  4. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2013, 10:36 PM
  5. Maxed Out = BS
    By Dboy23 in forum General Tech Discussion
    Last Post: 09-21-2008, 12:55 AM
