Yah, I'll send it over.
I think I figured out why the injector flow rate chart starts at -50kPa. I believe that they screwed up and it should read from 10-160kPa which would make since since 101.3 is atmospheric pressure so anything higher than 100kPa on a return style boost referenced system will have the same flow rate since the net pressure is still the same.
Jeff
