Thread: Help tuning tcc using dhp! Flash kr problem.
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 Help tuning tcc using dhp! Flash kr problem.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys i have my topswapped tuned on 91 octane running 14.5* of timing. I have 0 kr going through the rpm range but if i smash on it and the transmission downshifts im getting bad flash kr around 8* sometimes more sometimes less. Ive read this is usually caused by the tcc not releasing soon enough. I have dhp tuner but i have no knowledge on how to tune the tcc. So anyone with some help or advice would be greatly appreciated! Thank you!
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Help tuning tcc using dhp! Flash kr problem.
    in the tcc unlock table, list here the throttle percentages and speed that it currently shows.
  3. #3 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
  4. #4 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
  5. #5 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
  6. #6 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Any ideas anyone?
  7. #7 Re: Help tuning tcc using dhp! Flash kr problem.
    in your 4th normal unlock table, lower the 234.xx down to 31.25 and see if that helps. if not then the lowest i'd go is 25%.
  8. #8 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Ok thanks
  9. #9 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    I lowered the tcc release tables and nothing changed with the flash kr.
  10. #10 Re: Help tuning tcc using dhp! Flash kr problem.
    in the dhp scanner is tranny stuff, scan that too. shift time and such.
  11. #11 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Ok i will try that as well thanks scotty. I dont know if it matters but i did notice i didnt get any flash kr from 2-1 downshifts justs 3-1 or 4-2
  12. #12 Re: Help tuning tcc using dhp! Flash kr problem.
    thats no fun. what if you dont mash it all the way, just enough to make it down shift, then get on it?
  13. #13 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Ill have to run a scan tomorow but i think i tried that before and still got some kr it wasnt as bad like 3 or 4* but it still happens
  14. #14 Re: Help tuning tcc using dhp! Flash kr problem.
    how many cells does all this kr happen for? does it fade off fast? or keep climbing on ya?
  15. #15 Re: Help tuning tcc using dhp! Flash kr problem.
    Just a FYI, 3-1 and 4-2 downshifts are not good on factory parts inside the transmission. I wouldn't do alot of those if I was you.
  16. #16 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Well i have been very easy on the car as far as downshifts go but i would rather figure out this issue so if for whatever reason im forced to mash on it i dont have to worry about blowing the motor.
  17. #17 Re: Help tuning tcc using dhp! Flash kr problem.
    Quote Originally Posted by suitercrew View Post
    im willing to bet its false kr, the tranny is what maybe taking a slow death.
  18. #18 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    I would have to look at the scan but ive monitered it with tpro and as soon as i slam it i get a half second of approximately 3.5* then it spikes to 7 or 8* for about 1.5 seconds then back down to 3.5 ish and then 1 and then its gone. From start to finish it probably 5 seconds of kr in total
  19. #19 Re: Help tuning tcc using dhp! Flash kr problem.
    maybe time for a hd tranny upgrade. you got the tuner, that part is easy now.
    aka i think your tranny hates you lol
  20. #20 Re: Help tuning tcc using dhp! Flash kr problem.
    A HD parts swap wouldn't change anything, only the diff and gear ratio is different. All the other parts like clutches/drums/input shaft are still the same between the two and both would suffer the same death. Better off just building a stronger unit.
  1. Tuning trans question / Major WOT problem
    By Frosty in forum PCM Tuning
    Last Post: 10-09-2012, 04:49 PM
  2. EGR delete w/o PCM Flash
    By GP98GTX in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-02-2012, 06:09 AM
  3. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
  4. 3k stall problem, is it tuning related?
    By Biggie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2008, 06:29 PM
