Thread: Knocking when it shouldn't
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Knocking when it shouldn't
    Bastard Reptile's Avatar
    Kansas City, MO
    Fuel trims should lock in at zero. What are the LTFT's at idle and cruise? Do you still have your stock PCM, or did you send it back to ZZP?
  2. #22 Re: Knocking when it shouldn't
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    Idle LT is -0.7 and cruise LT is -2.3 if I remember correctly, I would need to look again though. But yes I sent the stock unit to ZZP, wasn't thinking I would have a problem you know?
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  3. #23 Re: Knocking when it shouldn't
    Kemmerer, Wyoming
    I liked my tune done by Overkill. Wires won't make any difference, except that they look cool. a bigger throttle body with a bigger mass air flow sensor, like the combination I have for sale in the classifieds, will increase the volumetric efficiency of the engine resulting in more power.
  4. #24 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    My mistake, cruising LT is 0.0-0.7
  5. #25 Re: Knocking when it shouldn't
    Within 3-5% of zero is just fine.
  6. #26 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    So an in-car tune it is to kill this KR? Any other things you can think of?
  7. #27 Re: Knocking when it shouldn't
    Kansas City, MO
    Weird, if the LTFT is that close, the trims should lock in at zero in PE.
  8. #28 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    What is PE?
  9. #29 Re: Knocking when it shouldn't
    PE= power enrichment. your car goes into pe mode when ever the gas pedal is 40% throttle or more on most set ups.
  10. #30 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    Jesus i have a lot to learn lmao it usually doesn't snap to 0.0 but something like 1.5 or so during these instances
  11. #31 Re: Knocking when it shouldn't
    when you do go wot the ltft should lock in at 0.0 but -5 to +5 is considered safe. closer to o.o the better.
  12. #32 Re: Knocking when it shouldn't
    Kansas City, MO
    The trims shouldn't be +/- 5 at WOT...there's a problem there if they do.
    Fluctuating at idle and cruise at +/- 5 is what's acceptable.
  13. #33 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    It snaps to 1.5 at WOT, no fluctuations.
  14. #34 Re: Knocking when it shouldn't
    Watch the wideband is what I always do.
    To me it does not matter if they are within 3-5% of zero and the wideband says I'm good on fuel. No way that that small percentage is going to matter really.
    The stock maf calibration on my 2012 silverado with stock airbox is within 2% of zero all the time and it doesnt change a thing.
  15. #35 Re: Knocking when it shouldn't
    Feb 2014
    Rhode Island
    I don't have a wideband however, can I bad wire cause knock?
  1. Why you shouldn't be tempted by 87/89 Octane in your GTP
    By Impala131 in forum How To Write-Ups/Tech Tips
    Last Post: 04-23-2013, 08:10 PM
  2. shouldn't have said anything
    By NR92 in forum Track Sessions and Kills
    Last Post: 07-29-2012, 09:06 PM
  3. ABS kicking in when it shouldn't be...
    By mikeplan14 in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2011, 08:10 PM
  4. why you shouldn't throw paperclips at co-workers....or should you?
    Last Post: 04-22-2011, 12:20 PM
  5. Various noises my car shouldn't be making
    By matt5112 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:24 AM
