Thread: 2000 GT tuning help
Results 21 to 40 of 51
  1. #21 Re: 2000 GT tuning help
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by ScottyDoggs View Post
    thats reading the o2 sensor, aka narrow band. its just not the same.
    What's a good wideband gauge? Anyone have one forsale? The problem is I don't have a spot for it in my 3 pod I already have 4 gauges in the car.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #22 Re: 2000 GT tuning help
    i have a PLX theres other brands out there. they pop up for sale here and there.
  3. #23 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    How come people say you can read the air fuel ratio through the o2 sensor with the aeroforce interceptor? People say 920 to 930 and zzp told me low to mid 900's and I'm good anything below 900 and it's to lean?
  4. #24 Re: 2000 GT tuning help
    not the same thing. its reading the actual air fuel reading out the down pipe. with its own wideband o2 sensor.
  5. #25 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    So what is the reading I'm getting from the o2 sensor?
  6. #26 Re: 2000 GT tuning help
    Bastard Reptile's Avatar
    Kansas City, MO
    The interceptor gauge reads what the PCM reads which is in Millivolts. A wideband has it's own controller, and readout so that you can see what your actual AFR is. Different brand O2 sensors will most of the time read different outputs. Which is why if you have a wideband that's a good calibrated setup, will tell you where you're at.
  7. #27 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by Reptile View Post
    Okay I have a oem ac delco o2 sensor would that be about the most accurate? My car runs at about 920 to 930 exactly where everyone says I should on a zzp tune. Should I buy a wideband? Just wondering if it's really necessary for being supercharged.
  8. #28 Re: 2000 GT tuning help
    your just not grasping this at all.
  9. #29 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    Not really when everyone tells you something different....
  10. #30 Re: 2000 GT tuning help
    900mv could be 11.5 afr on one car but 12.0 afr on another. Or it could be 930 for 11.5 but 11.0 on another car.
    They aren't accurate, they aren't a reliable source for real air to fuel ratio.
  11. #31 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    Its has to be close though right? Why isn't it as accurate doesn't make sense. Why would people say low to mid 900's and I'm good then?
  12. #32 Re: 2000 GT tuning help
    Quote Originally Posted by Tonkin2000GT View Post
    It's because those people don't have ther own tuning software and have likely never used a wideband.
    I've seen guys with $60,000 caddys ask why they should need a wideband sensor after they have already dropped another 5 grand in mods on the car. Like it never even dawned on them that they needed to watch this kinda stuff when you are making 700whp.
  13. #33 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    ZZP is one of the people that has told me this.
  14. #34 Re: 2000 GT tuning help
    ZZP isn't well liked around here for these kinds of reasons.
  15. #35 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    Yea I'm not a big fan anymore this would be why I was forced to buy headers... After there pos rear plog leaked because there welder warped the flanges...
  16. #36 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    The issue is I don't have a tuner anyways the car runs good but wondering how much better it can run with a good tune....
  17. #37 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    What's a good air fuel ratio with a wideband? What's the best wideband to buy? I have dual aeroforce interceptor gauges a auto meter sport comp ll boost/vacuum gauge and a oil pressure gauge now any ideas?
  18. #38 Re: 2000 GT tuning help
    The general rule of thumb is 11.5 as a target AFR for turbo/supercharged cars.
    You can start there and work around it if you had too. Some vehicles require a 11.0 to run problem free and some can go leaner to 11.8 or whatever and still be fine.
    Any of the gauges that most of us buy are $150-200 dollars. I've ran two AEM gauges and hard no complaints. Innovate LC1 is a gauge, autometer makes one.
  19. #39 Re: 2000 GT tuning help
    ditch the boost gauge install wb in its place.
    11's to 12 is pretty safe wot on a wb.
  20. #40 Re: 2000 GT tuning help
    Jul 2015
    Jamestown, NY
    Is there anymore mounting spots for gauges that people use for 97-03 grand prixs?
  1. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
  2. Replies: 9
    Last Post: 09-12-2011, 05:59 PM
  3. 2000 GTP info center in a 2000 GT?
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 01:24 PM
