Thread: '01 GTP Rich Condition
Results 1 to 20 of 23
  1. #1 '01 GTP Rich Condition
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I should start off by saying I know nothing about tuning, and I just happened to read the sticky about the rich condition when removing the rear O2 sensor. I have an '01 GTP with ZZP 1.0 PCM and I have the rear O2 simulator as a replacement. I still have a catted 3" DP so my question is am I having this rich condition? I dont have my Aeroforce installed yet, but when I go WOT on the highway, i can smell lots of fuel when I let off. Is that normal? What will happen if I keep it that way? Im not worried about inspection because they just plug in to see if any codes (which there are none).
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: '01 GTP Rich Condition
    if you smell raw gas id be looking for a leak somewhere.
    if you were super rich you'd be smoking black out the tail pipes.
  3. #3 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    I dont suspect a leak becasue the Plog is brand new with new gaskets. the DP is kinda old but the catback is brand new and everything was put of professionally. Also no sound when im under car with it running. I have never been able to see the color of smoke out the exhaust, Im going purely off the sticky above. Where I would fall under that catagory
  4. #4 Re: '01 GTP Rich Condition
    i mean a fuel leak, not an exhaust leak.
  5. #5 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    Ooooh, I have never looked. How would I check? Wouldnt it not have enough pressure to run injectors anyway if there was a leak?
  6. #6 Re: '01 GTP Rich Condition
    oh it can leak and still run just fine. the quick connects on the top of the sc to the rail, those can leak. and a rusted almost through line can also drip. filter can also rust through.
    this is if your smelling raw gas, like it just came out of a gas can type smell.
  7. #7 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    I'll have to check everything out, the quick connects are in good condition. Not rusted as I can see. I will need to look at everything else. So you think nothing is wrong with running rich at WOT? It just hit a nerve and I figured I would ask
  8. #8 Re: '01 GTP Rich Condition
    i have no idea if zzp kills the cat test or not, did they set the code to no report?
  9. #9 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    I believe it does, I didn't get any CEL codes.
  10. #10 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    I should also note, I only smell gas at WOT. Never just cruising around
  11. #11 Re: '01 GTP Rich Condition
    Donating Users Uno99's Avatar
    Appleton, Wi
    Quote Originally Posted by ScottyDoggs View Post
    ZZP does not I have one of their 1.0 PCM and have this issue on it. It still dumps fuel from time to time.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  12. #12 Re: '01 GTP Rich Condition
    GTP Level Member buickman104's Avatar
    NYC
    Yup on a ZZP canned tune in the cooler weather my car sits at -9 LTFT to -18 LTFT an has terrible fuel economy. Same thing with my Buddy's Bonneville SSEi with a ZZP canned tune.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  13. #13 Re: '01 GTP Rich Condition
    Bastard Reptile's Avatar
    Kansas City, MO
    ZZP deletes the check engine circuits in some of the PCMs too...even if it should throw a code, it probably won't.
    OP needs to clarify. You say you smell fuel. Is it gasoline? Or are you talking about the exhaust fuel stink. They are two different issues that address two different problems. It could be that the down pipe isn't sealed, and you're getting the un-burned fuel smell in the cabin.
  14. #14 Re: '01 GTP Rich Condition
    Feb 2014
    Rhode Island
    So they don't delete that code, okay. I only get fuel smell at WOT runs through the RPM range. And it smells like raw gas, like you were to dump it on the ground. I don't think I have any exhaust leaks, everything was put on professionally and very recently, all with new gaskets. It seems to just be the dumping of extra fuel, I can't see my fuel trims because I don't have DHP or HPT and my Aeroforce isn't set up yet. The car doesn't run poorly, it actually runs really good. I change my plugs to AL104s a few weeks ago and the old plugs looked great for 85k miles on em.
  15. #15 Re: '01 GTP Rich Condition
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    I would seriously get that checked ASAP if I was you...
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  16. #16 Re: '01 GTP Rich Condition
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    I know this is an old thread but I am having a similar issue. At WOT my AFR (Innovate MTX-L gauge) drops to 10.5 and when I let off the throttle I can smell what seems like an exhaust soot/running rich smell for just a second after (with a window down and / or sunroof open). Any other time driving around my AFR stays bouncing around 14.2 - 15.5. This is all with a ZZP canned tune. No KR, Gen 5, N*, EGR delete, LQ4, 3.4, TOG, Random Technologies DP/CAT, Comp Cams cam, Bosch #42 injectors blah, blah, blah.... Other than the WOT AFR and a P0420 code (w/ no CEL) which I cant figure how to fix for the AZ plug-in emission test, things seem to run ok. I have been talking with Tim from ZZP and he said that he has never tuned for the green Bosch #42 injectors but set it up for blue #42 injectors. I found this comment to be a bit curious since they sell the Green Bosch injectors. BTW, my green Bosch injectors are legit from Summit Racing and drop shipped from Bosch. Anyway, I feel that 10.5 is way too rich. Tim stated something about the enrichment tables for the open loop/WOT fueling. Does this make any sense to anyone? I would love to purchase a HP or other tuning program and tinker with tuning but funds for that are a little scarce ate the moment. Any ideas from anybody?
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  17. #17 Re: '01 GTP Rich Condition
    I still think it's not uncommon to smell raw fuel or exhaust after you let off the throttle after a WOT run. Depending on exhaust setup and if any minor leaks will allow the smell to swirl around the car.
    Yes 10.5 is a tad rich and ideally a 11.5 or so is a preferred target AFR to be at. But with only a ZZP canned tune that might not even be 100% correctly setup for the mods you have, it might be best that you are running that rich to possibly keep the car from seeing knock.
    Your head work and valve train/camshaft upgrade is helping a ton with air flow and keeping heat down.
    You can adjust the power enrichment settings to bring the air fuel ratio up some but I wouldn't touch anything yet. ZZP cannot and never will be able to custom tune for the mods you have, it's just not possible. You can't just toss a different throttle body, maf sensor and camshaft in the motor and think that regular generic tables plugged into a computer are going to right. At a minimum it needs a custom MAF tune to correct for any errors because that MAF is larger and flows a different amount of air into the motor. Then you work on timing and fine tuning your WOT fueling.
  18. #18 Re: '01 GTP Rich Condition
    Kemmerer, Wyoming
    on my last grand prix, when I would stop at the stop sign on the off ramp from the interstate I would smell fuel, even with the windows up. I never thought anything of it, and never had any real issues with the car, finally getting rid of it at 200,000 miles. without actually owning a tuner, there isn't much you can do. with my current car, I have worked with Will from overkill, but I have a tuner and take scans then email them to him for adjustments. Like 5fingerdeathpunch said, 10.5 is a tad rich, but you are likely not losing much power being that rich. my car typically runs in the 10's as well, I just haven't cared enough to do anything about.
  19. #19 Re: '01 GTP Rich Condition
    May 2008
    Schuyler, NE
    Sounds like you have a good running car. Unless you want to get a tuner, you can't do much.
  20. #20 Re: '01 GTP Rich Condition
    Apr 2009
    Peoria, Arizona
    Thank you everyone for the insight. I was being optamistic but I figured that the ZZP canned tune would be good to get me on the road but not optimal for my specific setup. I guess that I need to find someone on this forum that lives in AZ and would be interested in making a few extra $$ to help a guy out, spend about $600 + for a shop to tune my car, or man-up and spend the cash for HP Tuners. Anyone know a tuner here in AZ?? Lol
  1. Why so rich?
    By FIRECHICKEN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2014, 10:14 AM
  2. rich fuel condition
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2014, 07:55 AM
  3. To rich?
    By Timing in forum PCM Tuning
    Last Post: 09-02-2014, 05:27 PM
  4. Cold thermostat causing rich condition?
    By EastBayGPSE in forum General Tech Discussion
    Last Post: 03-03-2014, 05:02 PM
  5. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
