Thread: Help
Results 1 to 18 of 18
  1. #1 Help
    GT Level Member 04GTP4dr's Avatar
    Jun 2015
    hastings, Nebraska
    So got a pcm form reptile and I can't get the security relearn to work. I got an engine code p1631 any ideas
    Sent from my SM-S920L using Tapatalk
  2. #2 Re: Help
    the security light on? will it crank at all? did it start and stall?
    security learn is key to on for 10 minutes, off for 10 seconds, 3 times, 4 th time turn the key to to run and then crank it, should crank and fire up.
    if you have a scanner, clear the code, then do the learn.
  3. #3 Re: Help
    Jun 2015
    hastings, Nebraska
    It did but then the theft deterrent cones on and reads in the dic starting disable due to theft system and now I can't get the windows or anything to row up
  4. #4 Re: Help
    well id put the stock pcm back in for now so you can drive and roll the windows up.
  5. #5 Re: Help
    Jun 2015
    hastings, Nebraska
    Ok I got 42lb injector I put in to...but I suppose you gotta which the stock ones back rite?
  6. #6 Re: Help
    sadley, you should put the stock injectors back in if you want to drive it. it will run and drive but the flow rate is way off. would be real rich.
    see if reptile can ship you another pcm maybe if you cant get the security learn done.
    for fun turn the key to run for 10 seconds, then off. then try to crank it, not sure how he sets up the relearn, some make it as i just stated.
  7. #7 Re: Help
    Jun 2015
    hastings, Nebraska
    He was telling me that I was going to have to follow zzp or intense relearn to a t to get it to start
  8. #8 Re: Help
    which..is what Scott suggested
  9. #9 Re: Help
    Jun 2015
    hastings, Nebraska
    Gotcha
  10. #10 Re: Help
    Oct 2011
    Toledo, OH
    That is for 97-03. 04+ is slightly different.
    Just did a relearn an hour ago following this and it worked.
    http://www.intense-racing.com/sec_relearn.shtml
    7"
  11. #11 Re: Help
    its a reptile tune, its set up like a zzp or intense pcm with a 10 second key to on then back off, next turn it will crank and run. they do this cause chances are its not the same osid # number, this saves you 30 minutes of your life.
    in the bin is a area to change the security settings.
  12. #12 Re: Help
    Oct 2011
    Toledo, OH
    Ooooh, wow. So yep I just checked mine and it is 600 seconds @ 3 times. Well I wasn't doing anything but laundry this morning any way lol.
    7"
  13. #13 Re: Help
    lol i hear ya, ive sat through till i figured that trick out myself.
    you can change it to 10 seconds, and 1 time. but once its learned its done so no sense changing it now i guess.
  14. #14 Re: Help
    Jun 2015
    hastings, Nebraska
    I'm gunna give that a try...clear all codes then hit it
  15. #15 Re: Help
    Jun 2015
    hastings, Nebraska
    ....this is all I get security light on nothing else turns on tryed the relearn again after the first 15 mins turnthe key off for ten seconds then when for the second 15 min period the security light when off then back then came back on n didn't do it again for the rest of the cycle. And is still after I've taken key out..any thought on wats going on?
  16. #16 Re: Help
    your not reading things right.
    key to run, count to ten, turn key off for 2 - 3 seconds, then try to start it.
  17. #17 Re: Help
    Jun 2015
    hastings, Nebraska
    Just once
  18. #18 Re: Help
    Jun 2015
    hastings, Nebraska
    That's all I get the couple of times I've tryed
