Thread: Premium and PCM
Results 1 to 5 of 5
  1. #1 Premium and PCM
    GT Level Member cojo's Avatar
    Flint Michigan
    Ok ive been running premium in my gt for a few months now. Well about a month or more it started shifting really rough here there. It steadily got worse. My gf got me an overkill pcm for my birthday a few weeks ago. The shifting started getting real worse. I took it to the dealership today, and they wanted to the put the stock one back on which they did but the also found that my cat converter was plugged. The car was great now, but when I got home I put the overkill back in and the car ran great, im assuming since the overkill changed the shift tables that the problem became more apparent. So the cat being plugged must of the been the problem
    Im assuming that running premium all the time plugged the converter...
    but since I got the overkill pcm now is it safe to keep running premium of should I go back to 87??
  2. #2 Re: Premium and PCM
    Banned - Busted For Scamming
    Feb 2009
    premium is always better than 87
  3. #3 Re: Premium and PCM
    Flint Michigan
    yea but cant rich fuels plug the cat ? like what happened to me
  4. #4 Re: Premium and PCM
    Feb 2009
    no if anything it helps as it burns cleaner
  5. #5 Re: Premium and PCM
    Donating Users mystic231's Avatar
    Michigan
    Is premium fuel a requirement of the Overkill PCM in a N/A car? If not why run premium?
    No. It wasn't the premium that plugged it. It may have been a "weak" cat to begin with and it could have reached the end of it's service life.
    Or you may have been buying poor quality fuel that just happened to be 93 octane. Back in the day I worked at a gas station across from Courtland Center (back then it was the Eastland Mall) and the only difference between our 87 & 93 octane was that the underground 93 octane tank had 800 gallons of ethanol added to it (with no pre-mixing)when they filled the tanks. With the low margin on fuel for the gas station owners you need a station you can trust.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  1. Premium fuel required!?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2012, 10:20 AM
  2. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  3. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  4. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
