Thread: Jeep control arm replacement?
Results 1 to 6 of 6
  1. #1 Jeep control arm replacement?
    Nov 2012
    Madison
    So my brother pointed this out on his 1996 grand cherokee.
    The front is rusted threw so the rubber bushing is exposed. He is freaking. I told him to chill and drive, till we get it.
    It's on the front passenger side.
    Anyone familiar with the replacement of these. Would we have to even lift it or just replace as is on ground.
    I would imagine I would have to soak the bolts ahead of time. I am wondering if I could even wrench these off in place.
    Be nice to sick an impact at it.
  2. #2 Re: Jeep control arm replacement?
    you need to lift the jeep to get under it for sure. then a breaker bar and a pipe along with some spray evey night till you get the new part, should be a easy swap.
    looks like it bottomed out too, may want to bend that edge back in if it dont match the other side.
  3. #3 Re: Jeep control arm replacement?
    Nov 2012
    Madison
    I don't know Scotty there is a crap load of room under there.
    When I did his brake line it was almost to easy with the wheels on the ground.
    I read some quick looks on some jeep forums and it looks like you can drop them in place/wheels on ground.
    As long is there is no tension on them wouldn't it work?
    I didn't really spend too much time looking at it but it did look pretty easy ,just two (rusty) bolts a side.
  4. #4 Re: Jeep control arm replacement?
    its a trailing arm pretty much, it just holds the front axle in place. id hold the body with a jack, just incase it moves with a bolt out. then have at it.
    air tools would make the job so easy tho.
  5. #5 Re: Jeep control arm replacement?
    Nov 2012
    Madison
    Thanks for the confirmation, Scotty.
  6. #6 Re: Jeep control arm replacement?
    Soak it alot, ALOT.
    Likely the bolt is rusted in place, I'd heat that ****er up with a MAP torch.
    You want to bolt that thing in and tighten it with the wheels on the ground.
  1. Body control module replacement
    By ClintonIntVen in forum General Tech Discussion
    Last Post: 12-19-2013, 11:37 AM
  2. Are these good replacement control arms?
    By Doug 97 gtp in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2012, 03:05 PM
  3. control arm bushing replacement 1999 grand prix gt
    By djamp1983 in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2011, 07:03 AM
  4. Trans pressure control solenoid replacement
    By PrixGT in forum General Tech Discussion
    Last Post: 07-06-2010, 09:21 AM
  5. Lower Control Arm Replacement LCA
    By Sykkel in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 05:19 PM
