Thread: Sparkplug non-foulers, Oxygen sensor
Results 1 to 6 of 6
  1. #1 Sparkplug non-foulers, Oxygen sensor
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have used these before on oxygen sensors. I am trying to use it on an Alero oxygen sensor. The sensor threads into the exhaust fine as well as the non-fouler. But the oxygen sensor will not screw onto the De-fouler. Which I think is weird.
    Maybe they are threaded the same? I wonder if I could hammer it on past the first thread, and it would work?
  2. #2 Re: Sparkplug non-foulers, Oxygen sensor
    Sep 2012
    Dealership
    Make sure that the sensor is not hitting inside the non-fouler. Stopping it from threading on...or you may need one that has a longer non-threaded spout
  3. #3 Re: Sparkplug non-foulers, Oxygen sensor
    Pennsylvania, USA
    Did you drill out the non fouler? I had to use two on my post-cat o2. Drill out one with a 1/2" bit and screw the o2 into that one, screw that assembly into the other non fouler, and pop that whole assembly into the hole.
    It works very well, I've had a high flow cat for two months now and no codes have been thrown.
  4. #4 Re: Sparkplug non-foulers, Oxygen sensor
    Aug 2012
    Chicago
    Yes I drilled it. It was hitting the inside of the non-fouler, the new oxygen sensor's tip was longer than the older oxygen sensor. I will need an extended one for it to work.
  5. #5 Re: Sparkplug non-foulers, Oxygen sensor
    Panama City Beach, FL
    SMH. Clearly the first time you've encountered a depth issue.
  6. #6 Re: Sparkplug non-foulers, Oxygen sensor
    Aug 2012
    Chicago
    Haha good one
  1. o2 oxygen sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 08:14 PM
  2. oxygen sensor
    By kenjr in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-24-2013, 04:34 AM
  3. Oxygen Sensor
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 05:50 PM
  4. Oxygen Sensor
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 06-15-2011, 12:55 PM
  5. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
