Thread: 03 alero brake pedal goes to the floor
Results 1 to 20 of 25
  1. #1 03 alero brake pedal goes to the floor
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have 1 2003 olds Alero 2.2 180,000 miles. When I received the car from a friend the pedal was low. They stated getting a hose replaced so I figured the system possibly had air in it.
    I bleed the brakes at the brake hose at two of the floor wheels because the bleeder screws were rusted and broken off. This did not help at all actually may have made it worse. I have bleed the system numerous times with no resolution. The master cylinder doesn't have an abs module attached, (not where I can see it) not sure if it has some other device. The pedal is firm when the car is not started.. Once started it goes to the floor.
    brake booster or hose? I haven't noticed the car running funny or any hissing noises when started coming from the booster area. Not losing in fluid either
  2. #2 Re: 03 alero brake pedal goes to the floor
    any chance the master's res went dry on you when bleeding the brakes? if so you need to bleed the master, then the calipers again.
    cracking the brake lines should work, but the bleeders can also be changed, a easy out should get the old one out then thread the new one in.
  3. #3 Re: 03 alero brake pedal goes to the floor
    oh, if bleeding the master and the calipers dont get the pedal back good chance it needs a new master cylinder.
  4. #4 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    No it didn't go dry , when I bleed the system, I kept checking. But I will bleed the master, first thing and then the wheels and see what happens.
  5. #5 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    Just bleed the master and the calipers, strange thing when i got to the driver front caliper it didn't release like the other ones. My helper said the brake pedal didn't go to the floor like the previous three wheels.....not sure if that's a indication of anything.
  6. #6 Re: 03 alero brake pedal goes to the floor
    so the front bleeder is clogged or not opening?
  7. #7 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    Well i used the brake hose bolt to bleed and some fluid came out but very minimal compared to the rear hose.. Even while having someone pressing on the break it still flowed out as if no force was pushing on it...
  8. #8 Re: 03 alero brake pedal goes to the floor
    maybe crack the line a bit more.
  9. #9 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    I cracked it until could wiggle the line but I will try again...
  10. #10 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    After reading around a bit, I have found that this issue is most likely related to changing the front pads, I have no clue why. The only thing I can think of is pushing the piston back into the caliper some how adds air to the system . I have no clue what Or why, it affects the brake pedal.
    I have found other posts with the same exact problem but no solution yet.
  11. #11 Re: 03 alero brake pedal goes to the floor
    pushing the piston in will not push air into the system that's impossible.
  12. #12 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    That was just a hunch.. Maybe a collapsed line, I have no clue. I did find a few other posts with the same issue.
    Is their any other things I should do. But no solution Also this car doesn't have abs...
  13. #13 Re: 03 alero brake pedal goes to the floor
    the master could just be bad. you got the car like this right?
  14. #14 Re: 03 alero brake pedal goes to the floor
    I'd be leaning towards a bad master cylinder.
  15. #15 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    Yes makes since, I got the car and the pedal wasn't as bad , but I could tell it wasn't right
    I changed front pads and it got worse. Reading around about how changing the front pads (pushing in the pistons can flip the seals in the master cylinder) making it go bad.
    My buddy owns a JY so I grabbed a used master, but its doing the same exact thing...so only thing now is to go buy a new master and see if that works.
  16. #16 Re: 03 alero brake pedal goes to the floor
    If that doesn't do anything then try new rubber lines
  17. #17 Re: 03 alero brake pedal goes to the floor
    make sure you bleed the mc before you buy a new one.
  18. #18 Re: 03 alero brake pedal goes to the floor
    did you bench bleed that used master then put it on, then re bleed the brakes?
  19. #19 Re: 03 alero brake pedal goes to the floor
    Aug 2012
    Chicago
    Yes I bleed it off the car then again on the vehicle and bleed each wheel numerous times... The rubber lines ....I can look into that next
  20. #20 Re: 03 alero brake pedal goes to the floor
    how did you bench bleed it? with tubes that goes into the reservoir?
  1. brake pedal goes down to floor...my error?
    By dmahlikGT in forum Brakes/Suspension/Chassis
    Last Post: 11-02-2012, 05:30 PM
  2. new brake lines and pedal still goes to floor
    By donalda in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2011, 10:41 AM
  3. brake pedal goes to the floor
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2011, 01:42 PM
  4. Brake pedal sometimes going to the floor while stopped
    By stotzbotz in forum General Tech Discussion
    Last Post: 10-05-2010, 07:29 PM
  5. Out of ideas, pedal to the floor
    By donkason in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2010, 10:52 AM
