Thread: 2000 mitsubushi galant over heating
Results 1 to 9 of 9
  1. #1 2000 mitsubushi galant over heating
    Jan 2013
    Tolono IL
    we have changed the thermo and the radiator and it still is starting to overheat when the car is sitting still with the engine on. i said it sounds like the thermo but im not sure on what it could be? any answers?
  2. #2 Re: 2000 mitsubushi galant over heating
    Sep 2011
    Copperas Cove, TEXAS
    water pump?
  3. #3 Re: 2000 mitsubushi galant over heating
    Feb 2013
    37.295091, -121.930053
    thermostat could be the wrong way or a cloged raditor/hose
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: 2000 mitsubushi galant over heating
    Jan 2013
    Tolono IL
    i was starting to think about the water pump but i didnt know if it would only overheat at stops if the water pump is bad. and how would i tell if the thermo is bad?
  5. #5 Re: 2000 mitsubushi galant over heating
    Jan 2013
    Tolono IL
    and also is there a test for the water pump?
  6. #6 Re: 2000 mitsubushi galant over heating
    Feb 2013
    an easy way to check if your thermo is bad is if the upper hose is still cold to the touch. also if your water pump is bad it should weap from the weap hole or make loud grinding noise
    EDIT: make sure your car is warmed up first before you check the upper hose
  7. #7 Re: 2000 mitsubushi galant over heating
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    fans kicking on ?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  8. #8 Re: 2000 mitsubushi galant over heating
    Jan 2013
    Tolono IL
    one does but the other fan turns on then stops when it goes back down....idk whats wrong with it. could it be that fan?
  9. #9 Re: 2000 mitsubushi galant over heating
    Jan 2013
    Tolono IL
    alright. so the damn fan still does not work. their were 2 fans idk why but it was not made for the car so I put the stock 1 one fan in and used all the same wiring and everything and it still didn't turn on. anyway I got tired of dealing with it so I decided to wire it to a switch and now the only time the fan will come on is when the car is off. I know its the cheap way of doing this but the car isn't worth anything to start with so I don't care. but any ideas how I can get this fan working when the car is on?
  1. heating
    By boomingchevy95 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2012, 07:40 PM
  2. heating
    By aaddonis in forum General Tech Discussion
    Last Post: 12-27-2010, 06:57 PM
  3. Over heating Help
    By hefner516 in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
  4. Over heating...
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 06:49 AM
