#1
Junkyard rescue of an '87 Dodge Power Ram 50
I break things.
01-22-2019
This little truck was shoved back in the corner of a small private junkyard in Virginia. All it needed was a little bit of fuel and a battery and it drove itself out.
It's a 1987 Dodge Ram 50 4WD single cab short bed with the G54B 2.6L 4cyl and a KM145 5 speed manual.
New truck. by Ben Stryker, on Flickr
After an ordeal getting it home, it's gonna sit for a little bit while I order parts and get the registration dealt with, but I'm happy with it. It's a little rough right now, but it'll clean up nice and look decent with the right tires and stance.
![](https://www.grandprixforums.com/image.php?u=36267&type=sigpic&dateline=1493777435&s=02c0a0ed50550fbcf92c5809621ebdcb)
04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
87 Dodge Ram 50: Junkyard rescue, resurrection in progress.
#2
Re: Junkyard rescue of an '87 Dodge Power Ram 50
01-22-2019
Everyone needs a beater truck. Nice find!
LS swap it?
#3
Nice find! That's the Mitsubishi Mighty Max clone, right ?
For the record : I am NOT a naked meth-head who shoves rocks up my butt.
#4
I break things.
01-22-2019
![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
BrandonHall10
LS swap it?
![th_winking](https://www.grandprixforums.com/images/smilies/th_winking.gif)
I'm keeping this one as fuel efficient as possible, maybe some mild mods but nothing too crazy... For now. ![th_winking](https://www.grandprixforums.com/images/smilies/th_winking.gif)
I would keep it Mopar if I was going to consider a V8 swap, but that much horsepower would eat the rest of the stock drivetrain as a snack... That would mean at least 1 ton axles, a beefy transfer case and transmission, lockers... That's a lot of money to drop on a truck that cost less than $1k. Lol
cheatah faheatah
Correct! My dad had an 88 when I was growing up, almost the exact same as this one but with an extended cab, and I've been wanting one ever since then.
#5
iirc tilt column and dash mount hand operated e-brake ?
#6
I break things.
01-22-2019
Where the handle looks like a T shifter and you have to push the thumb bottom and twist to release it? Hell yeah. Lol
#7
01-22-2019
that looks like a fun truck, I hope you have better luck with this one than you had with the grand prix
#8
GTP Level Member
01-22-2019
My uncle had a 1 ton mighty max he beat the piss out of it but it was a 2wd.
Sent from my SM-N920V using Tapatalk
#9
I break things.
01-22-2019
This one has had the snot beat out of it already, but it refuses to quit. lol
#10
I break things.
#11
A/C ...resurrect or delete ?
#12
I break things.
01-27-2019
It's all still there and it's actually still charged. Just have to figure out which wire controls the compressor clutch and find the corresponding switch inside and make those two into one wire and I'll be in business.
I've got a few other things to delete and block off, and then a few everything to find plugs for, but once the Weber carb gets here I should be able to figure out all the connections it needs and be ready to to start it up. It still needs a new ignition coil, but I can toss an MSD Blaster coil or whatever in it. The mechanical fuel pump does still squeak when you manipulate the lever, but since I'm going with the Weber I'm putting the electric fuel pump in the back next to the tank.
Then it's just header, spark plugs, a few wires and it will be running...
#13
I break things.
01-27-2019
Ordered the header ($88) and got an MSD Blaster 2 coil, just waiting on Redline Direct to email me back about the Weber carburetor kit and I should be able to get it running. I also ordered some cheap shocks and extra gaskets, in case I want to fix any of the oil leaks get bad enough.
I also got some Grade 8 bolts to mount the bed and rear bumper, along with some interior bulbs. Oh, and a cheap head unit.
#14
I break things.
01-30-2019
Ordered the Weber 38/38 DGES K610 kit... That, the header, 2 1/2" exhaust and an upgraded ignition system should really wake up this little 2.6L and give it better throttle response, low end power, and open up the top end a little.
I've got a lot of parts coming in the next couple of weeks, and I'll have this weekend and the next to get everything installed and all the other little details dealt with. Once the truck is running I can finally take it over to the car wash, get rid of the moss that started growing on the roof and hood... Lol
#15
I break things.
02-02-2019
Pic of pile of parts on table as requested by ScottyDoggs.
Parts by Ben Stryker, on Flickr
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#16
GTP Level Member
02-02-2019
Decent size pile you have there sir
#17
02-02-2019
next request, parts installed and truck running lol
coming right along i see.
![](http://i.imgur.com/In0Qnqi.jpg)
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#18
02-02-2019
#19
02-02-2019
those be some, LOOOOONGGGGGGGGG tubes there lol
#20
I break things.
02-02-2019
I need all the torques I can get, this engine barely makes 100 hp at the crank in stock form.... lol
This engine is a hemispherical head design, and with the engine being manufactured by Mopar it does have a claim to the Hemi title. I should get some Hemi badges for it... lol
