Thread: Whole rack and pinion is moving causing a knock/thud
Results 1 to 3 of 3
  1. #1 Whole rack and pinion is moving causing a knock/thud
    Oct 2015
    I have a 99 grand am I thought I had a bad tie rod but under closer inspection my whole rack shifts on the bolts. The bolts are tight, is there some sort of spacer or bushing that could be worn out?
    I haven't messed with many racks other then the one on my 94 camaro and that was just 2 bolts and that's it
    Sent from my SM-G900T using Tapatalk
  2. #2 Re: Whole rack and pinion is moving causing a knock/thud
    GrandPrix Junkie
    St. Louis
    There are bushings in there. Swing by any parts store and grab some new ones. Should be cheap.
  3. #3 Re: Whole rack and pinion is moving causing a knock/thud
    pretty sure theres only one bushing on one side, if its moving the bolts might be the wrong size in there. aka to thin. and if they are tight they should be pinching the bracket and holding it tight too.
    might be a busted rack ear where it bolts through.
    and yup, only one bushing. its on the pass side.
  1. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  2. Rack and Pinion Help???
    By ill12will8 in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2012, 03:34 PM
  3. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  4. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
