Thread: 2000 suburban 5.3 l bad intake gasket?
Results 1 to 17 of 17
  1. #1 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Pretty sure I have this diagnosed as a leaking intake manifold gasket that seals up when warm. Has a lean code on both banks. P0172 and P0174 iirc
    Here is a cold start at -5 F with the block heater plugged in. Idle surges for 45 seconds or so when temp is below 10F. After it warms up runs great and runs great on any other start that day.
    https://vimeo.com/198207399
  2. #2 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Sorry video error on my part. I will grab one tomorrow.
  3. #3 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Got the parts already. Will do the knock sensors while I'm in there.
  4. #4 Re: 2000 suburban 5.3 l bad intake gasket?
    might want to change the k/s harness while your there too, they get beat up from the heat and can and will break if they want to. if yours has them foam inserts at the front and rear of the manifold toss them in the trash, and then you'll want to rtv the foam covers over the knock sensors to seal them up, the rear one will likely be full of water. the rtv stops that.
    like so.
  5. #5 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Yep saw that on you tube. Picked up a new harness and RTV as well. Thanks for the tips. Hardest part seems to be not breaking any 17 year old plastic parts you have to undo.
  6. #6 Re: 2000 suburban 5.3 l bad intake gasket?
    the evap line down the back of the engine is a fun one. other then that its not all that bad, dont loose the fuel line o rings, they are 40 bucks to replace with ones that work. dealer only item. you can use other types but they all seem to leak later on. yes, i lost one, only to find it over a year later in the gravel driveway i was working on.
  7. #7 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Are those at the main rail disconnect? I planned on leaving the rail on the intake.
  8. #8 Re: 2000 suburban 5.3 l bad intake gasket?
    theres a hard fuel line over the top of the manifold, pretty sure it had to come off. i ended up removing it. its been like 4 years since i did the job so all events are foggy at best. i recall all the headaches tho like it was yesterday lol
  9. #9 Re: 2000 suburban 5.3 l bad intake gasket?
    Aug 2011
    'Merica
    Did this to my Silverado as well. I removed the fuel rail iirc. There is a special tool you are supposed to use to disconnect the lines for the rail. i cut a sharpie cap in half, the sliced one side down the middle so it can fit over the rail. Press it into the clip and it should come free. Its been a few years as well for me, so all of the steps seem foggy too.
  10. #10 Re: 2000 suburban 5.3 l bad intake gasket?
    Quote Originally Posted by Below Average Joe View Post
    the same fuel line quick disconnect tool we use for the gp's works to get the line off the rail.
  11. #11 Re: 2000 suburban 5.3 l bad intake gasket?
    Aug 2011
    'Merica
    Sharpie cap was free dollars. I'm cheap.....
  12. #12 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    If I pop the fuel rail off do I lube the o rings with oil or something when reassembling?
  13. #13 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Fricken Murphy's law. Threaten to put a wrench to it and it starts fine. -9 F cold start block heater plugged in this am and I do the video right and no surging. Solid idle.
    https://vimeo.com/198347543
  14. #14 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    It was 42 today so I decided to just change the knock sensors and gaskets. Did notice a mouse was constructing a nest in an area where I thought the intake was leaking. Maybe some crap sealed it up. Anyway dove in. Pretty straight forward. Lots of cleaning to do.
  15. #15 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Took about 4.5 hours. With the cleaning.
    Did the RTV trick
    https://vimeo.com/200284458
    Seems to work!!
  16. #16 Re: 2000 suburban 5.3 l bad intake gasket?
    GTP Level Member
    Oct 2014
    Before gaskets placed.
  17. #17 Re: 2000 suburban 5.3 l bad intake gasket?
    she cleaned up nice.
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
