Thread: Project LQ4 - V8 S10 - Sold.
Page 24 of 66 FirstFirst ... 14222324252634 ... LastLast
Results 461 to 480 of 1306
  1. #461 Re: Project LQ4 - V8 S10 - Making connections
    im willing to bet its a mini welding table/ vice.
  2. #462 Re: Project LQ4 - V8 S10 - Making connections
    Why did you need an extra injector harness?
    So many compaines make direct drop in injectors for LS cars/trucks.
  3. #463 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Quote Originally Posted by spazzz View Post
    I really like your threads man.
    You have some skills.
    Thanks! Kinda learning as I go.
    I will be building a bench like that in spring once the grill takes a permanent home on the deck instead of the garage.
    I love that workbench. Easy to build, and very little scrap when done. Takes a serious amount of weight too. Here's the plans:
    http://www.familyhandyman.com/worksh...bench/view-all
    I have been browsing for vices. Whats with the aluminum stock under the vice? How do you have it mounted?
    Actually, that's just a chunk of 3/8" hot rolled plate. Local steel supply place had a stack of drops on sale for $13. I grabbed one thinking it would make a nice portable welding plate. The vise is just something I found on craigslist. Currently not mounted. I will eventually, but I've been doing so much cutting and grinding I wanted to do it outside of the garage to keep the mess out there. So I just set the vise on my workmate in the driveway.
  4. #464 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Didn't really NEED a harness. Just figured it would be the cheapest way to get 8 EV1 pigtails. Eventually, I plan on doing an injector upgrade. Currently, my harness is set up for the Multec 2 injectors. I can get any kind of EV1 injector way cheaper than a Multec 2 injector. As I'm sure you know, the stock LQ4 injectors are only just over 25#. I was thinking of just throwing a set of stock GTP 36# injectors in for the time being. Even those would be more than 40% bigger, and I can get 8 of those dirt cheap!
  5. #465 Re: Project LQ4 - V8 S10 - Making connections
    Nov 2012
    Madison
    Cool cool
    Yeah I have built the same style a ton at work for storage, benches, ect.
    For home I will probably do a 3/4 top or two 1/2" screwed and glued together.
    Geesh buying a vice seems to be a painful shopping experience.
  6. #466 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Alright. I think I have it thinned down to the bare essentials. Still a lot left.
    I guess you gotta start somewhere. So, I started with the injectors.
    I'm really tempted to completely de-pin the PCM plugs and individually route each component. For $22 I can get over 100 of the female pcm pins, and I already have the crimping tool...
  7. #467 Re: Project LQ4 - V8 S10 - Making connections
    you make it look easy some how, but all we see is the progress, we miss out on all the diagrams your following. and that head banging lol
  8. #468 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Honestly... It really hasn't been too bad. No major hurdles. When I step back and look at where it's at compared to where I started, sure I've come a long way. Really though, it's just a matter of taking it one small step at a time to add up to the finished product. Like I say to the kids when they have a seemingly overwhelming task in front of them; "How do you eat an elephant?" To which they roll their eyes and respond "One bite at a time, dad." Then I say, "Start chewing sucker!"
    Not a lot of that yet. I don't anticipate too much confusion until I start merging the two harnesses together. Even then it shouldn't be too bad. Just gonna take it one wire/circuit at a time. So far, my biggest frustration are those stupid fuseable links. They merge like 5 wires together so it's impossible to isolate one component. I predict I'll be burning through a lot of solder and shrink tubes.
    I did drop $10 on some Ebay PDF factory service manuals yesterday. Should be worth the cost just for the wiring diagrams.
  9. #469 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Got my $8 door handle today. Couldn't be happier. Popped the old lock out and the new one in. Within 15 minutes the handle was in and the panel was on. So nice to have two new locks, two keys and a fresh ignition cylinder. Not to mention, the peace of mind knowing the previous owner doesn't still have access to your truck.
  10. #470 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    I got another piece of the puzzle late yesterday.
    I figured running the stock 4.3 rad with auto trans and AC in a Tucson summer was a pipe dream, so I wasn't even going to mess around with it. Decided to spend the long dollar on the ECP S10 conversion radiator. Almost everything I read across many forums about ECP products was positive, which I think says a lot. Also decided to upgrade to the dual 1600 CFM fans after speaking with Frank at ECP for nearly an hour. It's supposed to be a direct fit, minus a little trimming here and there. We'll see...
    I just need to hit the side tanks with a scotchbrite to knock the shine off before I (very carefully) drop it in.
    I think now that I have the rad, I'll go ahead and put the front end back together. Two reasons for doing this; I'll be able to re-install the battery and troubleshoot active/working circuits, and if for some reason I need to put the truck outside, the engine compartment will be water tight. I can leave it in the driveway indefinitely without it being a half complete eye sore.
  11. #471 Re: Project LQ4 - V8 S10 - Making connections
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    My name is James, and I support this bad-assery. March on soldier.
  12. #472 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Quote Originally Posted by JamesIvey24 View Post
    Thanks for the support!
    Did a little brainstorming and I think I have the radiator support figured out. Just some 1" angle directly mounted to the core support.
    This is just a mock up. It still needs to come apart. I have to run to the hardware store tomorrow for shorter bolts, lock nuts and more vacuum hose. Also, the angle needs a coat of paint.
  13. #473 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Found a super easy solution to something I thought was going to be a huge pain. I thought I needed two coolant temp sensors. One to feed the PCM (left front head), and one to feed the gauge in the dash (right rear head?). It's nearly impossible to get to the sensor port/tap in the right head once it's crammed into the truck. So I started doing a little research. Turns out, someone figured this out long ago just using a stock 3 pin sensor from an early LS1.
    Stock sensor left, new sensor right
    And a new pigtail to go with
    The "A" and "B" wires in the new pigtail replace the "A" and "B" wires from the original coolant temp sensor plug in the LQ4 harness to feed the PCM. The third "C" wire will splice into the S10 harness and feed the IPC. Simple!
    I guess guys have been doing this for years and it works great. Another problem solved using off the shelf factory GM parts.
  14. #474 Re: Project LQ4 - V8 S10 - Making connections
    Aren't grand prix temp sensors the same 3 wire too?
  15. #475 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Possibly the same connector. (?) The threads are different though. Different part number for sure.
  16. #476 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    Got the radiator mounting complete. 1" angle bolted to the bottom of the core support with slit vacuum hose as a cushion. I decided to bolt rather than weld incase I ever do the 98+ facelift. Then I can just transfer the angle iron to the new core support. I forgot to get a picture of the finished bottom with the radiator mounted, but it's very similar to what I had before. Just now it's painted and the vacuum hose runs the full length.
    Inside the engine compartment looking forward and down
    Under the truck looking up
    For the top, I went with a couple straps of 1" flat stock bent to suit. Again, using slit vacuum hose as a cushion. Just enough to hold it forward against the core support.
    With a little bit of trimming, I could still get the original factory upper fan shroud on there. That's probably something I'll do further on down the road to maintain the look I'm going for.
    Once I was happy with the radiator mounting, I very carefully set it off to the side and worked the core support back onto the truck
    Still need to run all the bolts in, feed all the wires through and secure the grounds, but it's starting to look like a truck again!
  17. #477 Re: Project LQ4 - V8 S10 - Making connections
    Mar 2014
    Tucson
    One step forward, two steps back...
    I was able to do a test fit of the radiator with fans. Interference for days.... The radiator by itself slid in and the shroud cleared, but the fans aren't even close to fitting. The hit the water pump pulley snout HARD. Gonna have to sink the radiator deep into the core support, so the whole mounting setup will change. Might even involve moving the condenser in front of the core support to get the required depth. More cut/weld/grind/paint.
    Gonna sit back, sip on a couple cold ones and see what I can do.
  18. #478 Re: Project LQ4 - V8 S10 - Making connections
    why not try the fans on the out side? like pushers. looks to be room there.
  19. #479 Re: Project LQ4 - V8 S10 - Making connections
    A single skinny fan could work too, but you'd have to buy one.
    I know if you can find like a volvo fan or ford fan, they are 2 speeds and rather skinny.
  20. #480 Re: Project LQ4 - V8 S10 - Making connections
    i had a pair of 16 inch pro comp fans iirc on my 03 gmc. . they kept the temps one degree cooler then the clutch fan.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
