Thread: Post Whoring - 5.5.1 - We have a turd in the punch bowl
Page 51 of 154 FirstFirst ... 41495051525361101151 ... LastLast
Results 1,001 to 1,020 of 3061
  1. #1001 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Feb 2013
    Missouri
    I tore my factory transmission down to the driven chains something like 6 times, put a new 4th shaft\clutches in, new TCS, PCS, and a new VB\CP with Sonnax upgrades and such. Then I ended up picking up a JY transmission from a Century (IIRC) and used parts from both transmissions to make one good one. Century transmission had plenty of life left in it, but I used a steel for the second stack of my factory transmission in it, stuff like that. Also picked up some GXP chains, and used the N\A torque converter since it was a LOT lower mileage and higher stall. I'm not 100% satisfied with the new transmission, but at this point I think it's the VB\Channel plate. I kept the one from the Century so I'm going to go through it and swap over what I can from this one. I might even just use the extra separator plate I have instead, since this one is drilled, and I think that might be it.
    http://s14.photobucket.com/user/boob...00%20GTP/4t65e
  2. #1002 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Aug 2013
    McDonald PA
    Gonna have some fun shoot some targets Sunday
  3. #1003 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Mar 2014
    Tucson
    Quote Originally Posted by Booba5185 View Post
    Woah.
    Steel, paper or "other"?
  4. #1004 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Aug 2013
    McDonald PA
    Quote Originally Posted by BrandonHall10 View Post
    Woah.
    Plastic jugs with water. Some tannerite. A couple half filled spray paint cans. Lol I have land so I can shoot whatever kind of target and round. Perks of not having to go to the range.
  5. #1005 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Feb 2013
    Missouri
    Woah.
    Yea, the Century stuff was and is just something to hold me over until I get a 7\8" chain set machined out (gotta get on that, I have it all set up just need the chain and set). I'm also thinking of saving for a new TQ converter and a 300m input shaft, along with new clutches and all that. It'll probably be after I take care of the rocker panel rust though.
  6. #1006 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Mar 2014
    Tucson
    What is this rust you guys are always talking about? lol!!
    I took a lot of pictures today. One picture of every bore in the valve body. This is just one:
    Best tool for auto repair: A camera!
  7. #1007 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    Where 4T65E's were born
    Any bores have too much wear?
    Sold.
  8. #1008 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Mar 2014
    Tucson
    I don't think so. None of the valves were scared and there wasn't any grit in there either. I feel good about it.
  9. #1009 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Hey Navy, totally random (but not really). How much of a PITA was it to change the A/C compressor clutch. Mine is started to make very faint and random sad noises
    2012 F150 STX
    - Gonna be a race truck
  10. #1010 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    Not hard at all with the right tool. Jack it up, take the tire off, remove the cover over the pullies and go to town. It just clears the frame/body. You might have to go under the hood to turn the wrenches
    Sold.
  11. #1011 Re: Post Whoring Thread 3.0 - Bill loves you long time
    ill vouch for its right there with the shield off. it was in the corner of my eye for a few days straight fixing that balancer leak.
  12. #1012 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Apr 2012
    Dayton, OH
    Can the puller be rented at AZ? Mine is starting to make some noise, would rather not replace the whole compressor and hassle with have it evaced out and what not.
    2012 F150 STX
  13. #1013 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    Sold.
  14. #1014 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Apr 2012
    Dayton, OH
    I just watched a video of a guy doing one on a different style compressor but it has the same clutch by the looks of it. Looks super simple. Looked on RA, OEM clutches are like 50 bucks so thats not bad vs new compressor + cost of evacing the crap out.
    2012 F150 STX
  15. #1015 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Apr 2012
    Dayton, OH
    Im gonna check clearances first and adjust if needed, i seen somewhere gap should be like .030 to .015
    2012 F150 STX
  16. #1016 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    Yeah you need the tool to gap it as well. The clutches always fail because the return springs loose their tension and the clutch drags. You could adjust the gap a little by pulling it out slightly til it's gapped correctly, but the springs may get worse over time and do it again. Can't hurt to try that first really. Unless only one of the springs failed and it doesnt rest flat and the gap would be different around the clutch. There are a few stops around it. make sure they're pulled all the way in.
    Also ours is pressed on, and has a nut as well, although the nut just acts as a safety I guess.
    the 3 not straight strips of metal are the springs. The top part with the 3 bumps are the stops. My old one had gaps in its resting position.
    Sold.
  17. #1017 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Apr 2012
    Dayton, OH
    It just requires a set a feeler gauges doesn't it? I probably have a bit of time left on my clutch it makes hardly any noise right now. But if it fails I hope it does it whike its still warm lol.
    2012 F150 STX
  18. #1018 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    I just eyeball it.
    I used feelers the first time and made it too large somehow
    Sold.
  19. #1019 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Apr 2012
    Dayton, OH
    I looked at the air gap and it didn't seem like anything was rubbing or uneven but i didn't check all around just from top view, there was what looked like properish gap.
    And my grandpa lost his set of feeler so yay new tools can be bought! Thanks for the info navy, don't see why more people don't do it that way vs new compressor.
    2012 F150 STX
  20. #1020 Re: Post Whoring Thread 3.0 - Bill loves you long time
    Dec 2012
    You can spin the clutch with your hand (just the top part that won't effect the gap) and listen for anything, and watch the gap as it spins around. You can also put a flashlight under it to see the air gap.
    I don't know, I've got all the tools to charge the Ac and still wouldn't change the compressor for that lol.
    Sold.
  1. Post Whoring Thread 2.0- DON'T DELETE THIS ONE
    Last Post: 03-16-2015, 08:52 AM
  2. Don't get your hopes up. It's still a turd.
    By Koniig in forum Members Rides
    Last Post: 08-15-2013, 06:55 PM
  3. New guy with a new turd
    By Slow04grandprix in forum Members Rides
    Last Post: 12-10-2012, 09:13 AM
  4. What have you been humping a bowl of yams?
    Last Post: 07-23-2011, 05:49 PM
  5. New forum = Pic Whoring
    By scooz14 in forum Visual/Body Modifications
    Last Post: 08-16-2010, 05:24 PM
