Thread: Corn burning... No, not E85!
Results 1 to 9 of 9
  1. #1 Corn burning... No, not E85!
    Mar 2014
    Tucson
    With the colder temperatures making their appearance, I though I'd take a couple minutes to share one of my other passions. Well, former passions. Not much need for it where I live now. However, back when I used to call Michigan home, I burned corn to heat my house. Here's how I did it:
    Pick up from the local co-op into six 55 gallon water/air tight pickle barrels. Those six barrels netted just over a ton. About 2300lb.
    Once home, I unloaded the barrels into the garage. Needless to say, backing a loaded trailer up a hill with a slight curve into a garage using a 2wd S-10 was a challenge.
    From there I hand dipped bucket loads into a home built pre-screener.
    That screener fed a vacuum chambered 4' x 4' x 4' storage bin in my basement. That white PVC deal on top is a second screener. It had a 1/4" mesh screen that allowed the corn to pass over/across and the dust and chaff fell through and was carried by vacuum up the smaller tube. Once past the screen the clean corn fell by gravity into the bin.
    Here's what I used to pull a vacuum in the storage bin. It didn't take much. The corn moved mostly by gravity. The vacuum's biggest role was for cleaning. The green and cream colored can was actually a gutted shop vac. It worked like a cyclone. I used that to catch a bulk of the corn dust to keep it out of the bag in stainless shop vac.
    Once all the corn was out of the barrels and in the basement bins, I used this vacuum chamber (35 gallon barrel) to feed a 5 gallon bucket. That was then dumped directly into the stove.
    All that to feed this little pig. I used to call it Mr. Fusion. I fed it pellets, corn, cherry pits, stale cereal, dog food, saw dust. If it would burn, and fit through an auger, it went in the hopper!
    I engineered and built every part of the system. I had it all dialed in just in time to move away. I even had the stove on a thermostat. To anyone considering a pellet or corn stove to get away from propane, I highly recommend it. It's a lot of work, but very rewarding.
  2. #2 Re: Corn burning... No, not E85!
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Very cool!
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Corn burning... No, not E85!
    Buffalo
    Awesome !
  4. #4 Re: Corn burning... No, not E85!
    How long would a bucket burn for??
  5. #5 Re: Corn burning... No, not E85!
    Mar 2014
    Tucson
    Depends on a ton of variables. Hopper on the stove held approximately 60 Lbs. On a mild day and night, one hopper could last more than 24 hours. When it got below zero, I'd go through that hopper in less than 10 hours. This was to keep a 960sq. foot house with single pane windows at 73°.
    I get a kick out of people talking about tuning their cars, cause I used to be that into tuning my stove! Fuel feed was constant based on demand (linear) or heat level selected. So to get the perfect tune I would tweak the incoming air. Based on:
    -Corn moisture level
    -Outside air temp (I pulled combustion air from outside)
    -Corn blend (usually ran a 75% corn 25% wood pellet mix)
    Big picture is, I used about 4 ton to heat for one winter. When corn was under $200/ton that was less than $800/ season. Vs. Over $2000 for propane.
  6. #6 Re: Corn burning... No, not E85!
    May 2008
    Schuyler, NE
    Very nice! Good bang for the buck, since I'm pretty much giving my corn away now.
  7. #7 Re: Corn burning... No, not E85!
    Mar 2014
    Tucson
    Ya, from what I hear and have seen, corn price is down right now. I'm not sure who, but for the last couple of years, someone was getting rich. Price went bananas. First year I burned, corn was CHEAP. By my last year (winter 2011-2012) it was cheaper to burn pellets. I hated burning pellets.
  8. #8 Re: Corn burning... No, not E85!
    Antioch, IL
    very nice, iv always wanted to try something like this, but with paper, mashing it into a log and burning that. Paper is free find it everywhere!
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: Corn burning... No, not E85!
    Nov 2011
    NY
    Definitely pretty cool, but a lotta work to save some $$$ : )
    might be better off making a nice mash, sell the ethanol to buy heating fuel... Lol
  1. Slicks 2001 Galaxy Silver GTP Now with corn
    By Slick2500 in forum Members Rides
    Last Post: 11-28-2015, 08:17 PM
  2. LS1 vs rocker IC corn car ( future race)
    By gojo83 in forum Track Sessions and Kills
    Last Post: 06-13-2013, 11:04 PM
  3. J-Liss Soon to be self tuned-corn fed stock w-body.
    By JLiss in forum Members Rides
    Last Post: 04-11-2013, 11:29 AM
  4. Corn on the cob
    By MrPoopyButthole in forum Visual/Body Modifications
    Last Post: 07-06-2010, 01:07 AM
  5. If you don't like corn dogs...
    By pontiacprincess in forum Off Topic Discussion
    Last Post: 04-05-2009, 06:44 PM
