Thread: Jasper Engines....anyone know anything about them?
Results 1 to 15 of 15
  1. #1 Jasper Engines....anyone know anything about them?
    PA
    I am going to buy a used engine for my truck. A guy locally has a Jasper engine that supposed to only have 10k miles on it. But I don't know much about Jasper engines.
    I know that the rebuilds that are done in Mexico are junk. But I thought Jasper was in the US. So are they any good?
    Anyone know?
    2001 GSE
  2. #2 Re: Jasper Engines....anyone know anything about them?
    Apr 2008
    Chillin at the Beach , VA
    I got a tranny for my GP from them and haven't had any problems. My friend back in VA works at a ford dealership and that's where they get all their motors and trannys from.
  3. #3 Re: Jasper Engines....anyone know anything about them?
    Saraland Alabama
    when I worked at the dealer in GA we replaced at least 1 of their garbage engines a week, they are not rebuilds, they will only work the cylinder that is damaged, and leave the rest in, I have seen 1 crank journal with a oversize bearing the rest are factory bearings (different brands and types)
  4. #4 Re: Jasper Engines....anyone know anything about them?
    Apr 2008
    Wow. Did not know that.
  5. #5 Re: Jasper Engines....anyone know anything about them?
    Saraland Alabama
    few of the rebuilders actually rebuild them, from looking at the ones sold through the parts stores, advance has a new brand that seems to actually do a true rebuild, and oreillys does also
  6. #6 Re: Jasper Engines....anyone know anything about them?
    Jul 2008
    sumter,south carolina
    ive never heard any complaints about jasper...my boss got over 300,000 miles out of one of their trannys in a F 250...that regularly got overloaded with trailer weight
  7. #7 Re: Jasper Engines....anyone know anything about them?
    Saraland Alabama
    tranny may be different than the engines, I never dealt with them
  8. #8 Re: Jasper Engines....anyone know anything about them?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I've been through the Jasper, In engine plant, as well as another up in that part of the country, and am not sure what a rebuild is if that's not what Jasper is doing. From start to finish it's an impressive operation.
    One thing that surprised me is that the final builders take the "kits" they get and build from there --- and that they seldom build the same engine type twice is a row. The tranny shops are a little different in that those guys pretty much hammer out whatever it is they are assigned to.
    I know the family that runs the place and you couldn't find nicer folks --- and the family aspect trickles across the company.
    That said, I've never used one of their products, so I have no first hand knowledge of their stuff.
  9. #9 Re: Jasper Engines....anyone know anything about them?
    Apr 2008
    I know they have been around for quite some time, but yea, never used any of their engines. Can only speak for the tranny side of the house.
  10. #10 Re: Jasper Engines....anyone know anything about them?
    PA
    Well, picked up the engine on Saturday. Looks like it has more than 10k miles on it. But I will have to see once I get it opened up.
    2001 GSE
  11. #11 Re: Jasper Engines....anyone know anything about them?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I hope you have good luck with it and being that it has 10K on it should put you in the safe zone. I wouldnt touch one with a 100' stick to be honest. I used to rebuild engines at a local shop and some of the garbage that was seen over the years was rediculous. Just boring out ONE cylinder and using one mismatched piston, and as mentioned above only grinding a few crank journals.... pretty sad but thats how a lot of it is done. I know in recent years things supposedly changed but I still hear lots of horror stories about the engines and transmissions, some guys going through 2-3 of either just to get something that works right. But on the other hand there are those that dont have any trouble at all.
  12. #12 Re: Jasper Engines....anyone know anything about them?
    Bastard Reptile's Avatar
    Kansas City, MO
    That's funny, because you can touch a lot of things with a 100' stick. LOL
  13. #13 Re: Jasper Engines....anyone know anything about them?
    Fort Wayne, IN
    Well just for your sake it is a 99' stick lol
  14. #14 Re: Jasper Engines....anyone know anything about them?
    Wichita, KS
    I have heard good, and I have heard bad from them.
    I have heard MORE bad than good, so thats my red flag.
    I have heard they are only interested in numbers and volume of "rebuilt" motors in, and back out the door, not only in record time, but in record volume as well.
    They take short cuts, do sloppy work, and rebuild them wrong more than half the time resulting in failure. Jasper's reps are pretty bad about taking responsibility on the failure, they like to blame the owner of the vehicle to the shop operator for doing the installment "wrong" resulting in the failure. Only when people called B.S. on them, and took the motors apart, thats when people started noticing how bad of a job was done on the rebuild.
    I have heard mis matched bearings...used parts reused that shouldn't be etc. were found inside on tear down. The shops then call Jasper back, they send a rep out, and then maaaaaaaaaaaaybe Jasper will warranty out the motor after they look inside. But I bet they try to say to the shops "Well you must of put in those parts cause we didn't".
    ~F~
  15. #15 Re: Jasper Engines....anyone know anything about them?
    Fort Wayne, IN
    There was a local guy probably 5-6 years ago that ordered a 4.3 for his 91 S10 and when they delivered the engine to the shop it was laying on its side in the Jasper delivery truck, one broken valve cover and two rocker arms trashed. They told him just to take those parts off of his old engine and put them on the new one! He unquestionably declined and ended up having a local shop rebuild his engine
  1. 94 Olds 442 462ci-4wd-2 (twin) engines
    By turbocharged406sbc in forum Oldsmobile Cutlass
    Last Post: 07-10-2014, 05:52 PM
  2. Bring on the Carnage!! part 2 Engines
    By TurboKent in forum General Tech Discussion
    Last Post: 03-24-2008, 06:19 PM
  3. Some bling for these engines...
    By GR8racingfool in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2008, 10:13 PM
