ok i can breath again lol sounds like a normal brake job. never know till its on a jack.
lol...no one said they weren't goin to strip once ur into the project..lol
just razzin ya!
OK...SERIOUSLY, THATS NOT FUNNY AND I PROBABLY SHOULDN'T HAVE SAID IT.
i wont be held accountable if anything strips and / or breaks on this project...![]()
I have a little too much experience with Honda's as I replaced literally every part including the Engine and Transmission except the Unibody of the vehicle on my 95 Accord. 94-97 the front brake rotors are behind the bearing hub which makes it a pain the first time you experience it, but now I do it pretty quick with extended bolts and an air chisel. For 99 the rotors would be normal except Honda decided to put 2 phillips head screws on the rotors. You need heat from a propane torch and an impact hammer. I use this one Impact Screwdriver Set with Case If you strip the threads you'll need to drill them out. I usually break the Phillips bits in the set and have to turn it in for the lifetime warranty by the end of the job. I didn't have any propane so I got one screw out on each side, but then had to drill out the other 2. I forget for 99, but if you're replacing the rear rotors, they have the Phillips screws in the 94-97 with rear discs. The calipers for the rear are screw in and the fronts are regular push in. For my rear caliper screw ins, I use this: 18 Piece Disc Brake Pad and Caliper Service Tool Kit (They have stores in NJ and I always use their coupons) You can usually just screw them in with needle nose pliers, but I had to use that tool as the rear brake line was shot and the one caliper was frozen. After I broke it loose, it works good now.
So, recommended tools besides the usual:
Impact screwdriver
Propane torch
Disc brake pad and caliper service tool kit
Sorry, I knew I forgot something. Everybody I know including me throws them away. They're basically there to line up the rotor without the wheel on. When you torque the wheel back on, they'll be like any other set of rotors.
O and one more tool, a 2-4 lb sledge hammer for the impact screw driver.
NP, I hate working on them, but I know a bit about them. Only the rear calipers are twist in. I think because of the emergency brake.
I'm always saying f*ing Honda, f*ing Honda. But Nissan is probably the worst because everything is designed to be so cramped. Sister's boyfriend has 2 300 ZX's. One of them the twin turbo. They're always fun to work on when he asks for a hand![]()
