How much stuff would i need to do to swap a n/a 3800 engine into my grand am gt
its alot of dorking around.
the cradles are differant, the wiring you would need to take both harnesses and cut splice remove what you need and dont,
yea if you have your heart set to it, its been done
my old 92 GA has a L67 in it now and the guy kept it manual
Actually after reading GA forums it seems to be a real wiring PITA since you have to make the GTP/GA PCM's piggyback each other.
You can always turbo your 3400...or do a cammed 3500 upper intake swap...should be good to run with a stock GTP that way...but that's just IMO.
