Thread: Rebuilding an Engine, Steam Cleaning Internal
Results 21 to 40 of 59
  1. #1 Re: Rebuilding an Engine, Steam Cleaning Internal
    Never Never Land
    maybe thats what i should do....shortblock from zzp.
  2. #2 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    Figure in $1500 of machine work and bolts. The steam clean you are talking about is the hot tank at the machine shop.
    SMGPFC Two Nipple General
  3. #3 Re: Rebuilding an Engine, Steam Cleaning Internal
    Largo, Florida, United States
    No I ment a real steam cleaner not a hot tank.
  4. #4 Re: Rebuilding an Engine, Steam Cleaning Internal
    with the new I/C and cam 42lb injectors and the rest of the mods im shooting for a 2.8
    but i just ordered my new R1 concept rotors and hawk pads.
    photos will be up in a year when i get home from Iraq lol.
  5. #5 Re: Rebuilding an Engine, Steam Cleaning Internal
    just dropped about $2100 in to parts
    and those D/S rotors 12.7 and the hawk pads from R1
    5th stainless brake line
    $24.99 $24.99 KYB AGX adjustable struts
    Model:Full set of 4
    Option 2:Set of 4 Strut Mount Plates $694.99 $694.99 Stainless brake lines
    Model:Stock lengths $109.99 $109.99 ZZP control arms for WBody
    Model:With sway bar end links
    Color:Red $499.99 $499.99 Anti Pogo washers
    Color:Powdercoated Red
    Option 1:Two pair $37.00 $37.00
  6. #6 Re: Rebuilding an Engine, Steam Cleaning Internal
    all braking and suspension is done now 100%
    GXP Calipers
    HAWK PADS
    Drilled and slotted rotors 12.7 front and 12' rear
    ZZP control arms
    KYB AGX Struts
    new wheel bearings x4
    new sway bar links
    new outer tie rod ends
    new powersteering pump
    new rack and pinion
    just gotta find some classy 18's or 20's to match the red/black theme and gotta order votland springs.
    everything is ncie and paid for... just gotta install it when i get back!
  7. #7 Re: Rebuilding an Engine, Steam Cleaning Internal
    Quote Originally Posted by Spartan GL View Post
    no need to even touch the motor for a 2.8 pulley. now youre just wasting money to waste money.
  8. #8 Re: Rebuilding an Engine, Steam Cleaning Internal
    yeah blue hit it right on the head. but i do want to put forged internals inside ya know and get the bottom end built proof.
  9. #9 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    I mean use a hot tank they work.
  10. #10 Re: Rebuilding an Engine, Steam Cleaning Internal
    didnt read anything above me.
    why are we building a motor for a car that isnt ever getting a small pulley?
  11. #11 Re: Rebuilding an Engine, Steam Cleaning Internal
    Jan 2009
    Tallahassee, FL
    Rebuilt 3800s just have a bad rep with not lasting long. They're just finicky, they're not as easy to rebuild as SBCs.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: Rebuilding an Engine, Steam Cleaning Internal
    Maybe yes maybe not take your time check and recheck everything all said and done say sh1t does go south you could STILL build another for less than ordering a ZZP engine. Just becasue they've built it what makes it so much better than what someone that did a little research, checked and rechecked everything have to lose? Besides they could save a ton of money that could be used else where. Not to mention a higher compression build with a bigger pulley would have to work less. Combine that with a good tune and you've got a cheaper engine that makes more HP, and didnt get raped on shipping!!!!!
    Hell the cost of shipping an engine alone is money to buy a CAM!!
  13. #13 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    they will last if you machine everything like you are supposed too, replace the tty bolts, and know what your doing when you put it back together.
  14. #14 Re: Rebuilding an Engine, Steam Cleaning Internal
    Odessa, MO
    Reptile's got over 10k on his rebuild and Bluegtp has over 6k on his (and no one thrashes on a car like blue. LOL) and neither are even close to stock. I think if done right, emphasis on that part, they will last. I realize 10k and 6k aren't a lot in the grand scheme of things, but I wouldn't hesitate on rebuilding another one. But then again, I'm a stickler for exact specs on everything which I think is the key to a successful rebuild.
    And as far as steam cleaning, never heard of it. Take the important parts, block, heads, etc. and have them boiled out at a machine shop. Just my opinion, steam is water, water and bare metal will equal rust if you don't get it together right away. If you do steam clean it and it's gonna sit a while, spray it all down with some WD-40 or something equivalent to keep any surface rust from forming.
  15. #15 Re: Rebuilding an Engine, Steam Cleaning Internal
    normally rebuilds, if they are going to, fail within a couple thousand or less.
  16. #16 Re: Rebuilding an Engine, Steam Cleaning Internal
    Jersey
    id just do a low mileage L32 with turbo kit and trans
    16' wrx sti- stock
  17. #17 Re: Rebuilding an Engine, Steam Cleaning Internal
    You could probably run a 2.8" on a GenV with those mods...might as well skip the GenIII since you like taking money and burning it religiously
  18. #18 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    add a snorkel to the list and you will be good to do. If you decide you must rebuild the engine dont skimp on the machine work that is with 90% of these fail.
  19. #19 Re: Rebuilding an Engine, Steam Cleaning Internal
    Jul 2008
    sumter,south carolina
    but seriously joey... u have come along way and going further with the car... good luck, hope it all turns out well.
    02 GTP with mods 05 GP for DD
  20. #20 Re: Rebuilding an Engine, Steam Cleaning Internal
    Florida
    whats with the sudden outbreak of people rebuilding their motors?
    Joey, if theres no real reason to completely tear the motor down, then dont.
    I'm doing mine because it blew...
    I dont really see any reason to have it totally disassembled, and rebuilt. Just throw that **** on there, and run it til it blows...THEN rebuild it.
  1. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  2. releasing some steam
    By cojo in forum The Rant Forum
    Last Post: 04-13-2009, 08:49 PM
  3. Cleaning up the engine bay
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 07:22 PM
  4. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
