Re: info on a GTP to GXP swap. any help??
I bought the last one on Morad's site.
my 2001 grand prix speedo went to 110.. i want that sucker to display the highest possible haha.
and im really interested in the g-force menu on the dic. i know its pointless..but friken awesome.
Actually i would like to know this as well. I wouldnt mind swapping out my DIC for one with tire pressure levels and gforce menu...hmmm.
REDCOMPG
welcome to the party....your a bit late :D
05CompG
systems won't work, you need to controlers for them.....not too mention you do NOT want to pay for the stems to have individual tire pressures...it isn't cheap.
200-300 for a set of TPMS sensors is normal around here.
boostedcompg
you will be faster....very much faster. i wanna eventually do the body swap. and you can that ls4 all you want...then detonate more expensive trannys instead of just building the 3800 and detonating less expensive trannys
ls4 and l67 both use 4t65e-hd trannys
the valve body in the tranny that comes with the LS4 is different because it has tapshift.
It IS more expensive lol.
LS4 tranny has the valvebody from a Comp G, but runs 2.93 gearings.
I have found a Comp G tranny in PA with 15,000 miles on it for $500...I'm gonna be picking it up I think....maybe.
DrunkietheBear
Well i already have TPMS but it doesnt show me the Level of each tire...did i mis read somethin? In the GXP does it tell you the level of each tire (i.e. RF is 35psi and LF is 33 psi) or is it just normal
You have a TPMS that detects the speed of each wheel to tell you if a tire is low. It can not monitor each tire individually.
Trust me, you want to keep the system you have...its Free (technically)....going to what the gxp has is alot of money to replace some damn valve stems.
mine tells me each tire :0)
tazyboy28
This is the one i want...LOL I wanna know each tire
05CompG
buy a tire pressure gauge thingy, and walk around to each tire and see what it reads. Its just that easy, amazing i know right.
bluegtp91
plus, I don't care much for the body of the GXP either
Son, I am disappoint.
GXP's have individual tire pressure readers too.
if you prefer the regular gp body over a gxp.. i just dont know about you lol
if u dont pick that tranny up ur a tard :)
would the 5.3 bolted to a gtp tranny with 3.29 gears even have a noticable difference you think?
