Thread: pwr steering pulley re-install problem
Results 1 to 4 of 4
  1. #1 pwr steering pulley re-install problem
    El Cajon
    I had to use a power steering pulley puller to remove the pulley in place so I could remove the last long bolt for the water pump to replace it. I install the new water pump and when trying to re-install the power steering pmp pulley. The installer (a rental) is to long and hits the car frame. Does anyone have an
    idea on what I can do to re-install the pulley. A Fabrication or Modification or anything that will help. Thanks for listening.
  2. #2 Re: pwr steering pulley re-install problem
    Portland Oregon
    First, you didn't have to take the pulley off. The power steering pump pulley has holes in it so you can get to the two 13mm bolts that hold the pump to the block off to do the water pump. But, since you took the pulley off, I once made the same mistake. Luckily my motor was out of the car at the time. You should be able to find a bolt to thread into the pump shaft, then use a nut and some washers to press the pulley on
  3. #3 Re: pwr steering pulley re-install problem
    El Cajon
    Thanks. Ive got a small threaded stud to thread into the power steering pump and was able to use the Installer I rented and Im putting everything back together today again thanks for the information and I will remember the 2 13MM bolts the next time because this way was to problematic.
  4. #4 Re: pwr steering pulley re-install problem
    you may want to put a metal straight edge across the pulleys to make sure its on far enough or not to far on, as if its mis aligned it will shred the belt over time, or sooner if its way off.
  1. Power Steering pulley FML
    By Joethebird in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2010, 03:59 PM
  2. steering problem
    By GTP Ryan in forum General Tech Discussion
    Last Post: 12-06-2009, 04:40 PM
  3. steering problem
    By stanggreg90 in forum General Tech Discussion
    Last Post: 10-16-2009, 10:05 AM
  4. power steering pulley tool
    By cuda010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 07:11 PM
  5. Steering Problem Please Help
    By 2000grandprixGT in forum General Tech Discussion
    Last Post: 03-08-2008, 02:00 PM
