Thread: what would cause such a rich fuel mixture the car dies and burns white smoke?
Results 1 to 7 of 7
  1. #1 what would cause such a rich fuel mixture the car dies and burns white smoke?
    GTX Level Member colindunn's Avatar
    Aurora, IL
    i know its rich fuel because it smells soo horrible of fuel everywhere. its not leaking though. it will start then you have to give it some gas, when driving (when it stays on) it drives fine untill you press down on the gas and it boggs down and shuts off. i took the fuel pump fuse out and then after a couple cranks it ran fine since it wasnt getting too much fuel. it also burns whiteish smoke that has a strong fuel smell. ALOT of white smoke. there is also a cooling system problem. are they connected? any help is appreciated
  2. #2 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    GT Level Member Perry125's Avatar
    maryland
    White smoke = coolant
    Black smoke = fuel
    I wouldnt recommend smelling too much of that smoke...
    I dont know if the rich condition and the cooling being burnt are connected, but id get the cooling fixed first..
    Im so USDM
  3. #3 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    Apr 2009
    stockton ca
    lim gasket would be my guess for white smoke
  4. #4 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    halifax
    head gaskets and it's missing hence the raw fuel smell.
  5. #5 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    Apr 2009
    Fort Worth TX
    I had a similar issue with my cousins car, a GP SE 2000 I think. Same symptoms, missing, stalling, raw fuel smell, white smoke. We pulled it into the garage and I noticed raw gas running out of the exhaust pipe. We very quickly bled the pressure off the fuel system and the leak slowly stopped. There were so many DTCs that we didn't even know where to start. The fear of burning the house down caused us to let it sit and dry out for two days, with the garage door open of course. I thought it had a blown head gasket (white smoke)...Pulled the radiator cap and system was full to the top with no contamination and no bubbles while running. As soon as we smelled the fuel we shut it down.
    I suspected a dead injector, stuck open. We pulled the fuel rail with the injectors still attached. The following I would not recomend but here goes. We cycled the key on and off to build up some pressure in the fuel system and sure enough #2 injector was spewing gas all over. Lucky we didn't have an accidental fire. But anyway, after replacing the injector and resetting the computer the car ran great.
  6. #6 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    maryland
    How does fuel make white smoke?
    Im so USDM
  7. #7 Re: what would cause such a rich fuel mixture the car dies and burns white smoke?
    Jul 2008
    sumter,south carolina
    im sorry but u would think ppl would know not to post mechanical questions in the lounge... u would get a helluva lot more responses in the correct section.
    02 GTP with mods 05 GP for DD
  1. P0172 rich mixture bank one. oxygen sensor?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:49 PM
  2. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-14-2010, 08:13 PM
  3. White smoke
    Last Post: 04-10-2010, 06:29 PM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. Jerking and white smoke
    By jhnath in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:51 AM
