Thread: Need some help with C++
Results 1 to 15 of 15
  1. #1 Need some help with C++
    GTX Level Member bronzemist02's Avatar
    Canada
    I am working on a college project for C++ that gets a user to guess a letter. The letters of the alphabet are held in a string from a project file that was asked to be modified for the project.
    I set the project file up very similar to that of another guessing game that I found coding for that gets the user to guess a number. I set up my code for this project to create a random number and assign the value to the letter string to get the letter. I know I haven't finished the calling for it yet.
    The last few times I went to run the program it came up with over 30 errors most of them to my string comparisons to figure out if the user is correct.
    Can anyone help me figure out how to fix these? I think I can figure out the calling afterwards if this is fixed.
    These are the errors I have:
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(42) : error C2082: redefinition of formal parameter 'x'
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(43) : error C2679: binary '>>' : no operator found which takes a right-hand operand of type 'overloaded-function' (or there is no acceptable conversion)
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(49) : error C2451: conditional expression of type 'std::basic_string<_Elem,_Traits,_Ax>' is illegal
    1> with
    1> [
    1> _Elem=char,
    1> _Traits=std::char_traits<char>,
    1> _Ax=std::allocator<char>
    1> ]
    1> No user-defined-conversion operator available that can perform this conversion, or the operator cannot be called
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(53) : error C2784: 'bool std:perator >(const std::basic_string<_Elem,_Traits,_Alloc> &,const _Elem *)' : could not deduce template argument for 'const _Elem *' from 'int'
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(57) : error C2784: 'bool std:perator <(const std::basic_string<_Elem,_Traits,_Alloc> &,const std::basic_string<_Elem,_Traits,_Alloc> &)' : could not deduce template argument for 'const std::basic_string<_Elem,_Traits,_Alloc> &' from 'int'
    1> c:\program files\microsoft visual studio 9.0\vc\include\string(130) : see declaration of 'std:perator <'
    1>c:\course technology\83618-4\cpp5\chap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(57) : error C2676: binary '<' : 'std::string' does not define this operator or a conversion to a type acceptable to the predefined operator
    This is what I have so far:
    //Ch12AppE04.cpp
    //Allows the user to guess a letter chosen
    //randomly by the computer
    #include <iostream>
    #include <string>
    #include <ctime>
    #include <iomanip>
    #include <stdlib.h>
    using std::cout;
    using std::cin;
    using std::endl;
    using std::string;
    using namespace std;
    string check (string guess, int x, int letter);
    int main()
    //declare variables
    string letters [26] = {"a","b","c","d","e","f","g","h","i","j","k","l"," m","n","o","p","q","r","s","t","u","v","w","x","y" ,"z"};
    string guess = "";
    int letter = 0;
    int x = rand();
    //ask the user to guess a number
    cout<<"Number: ";
    cin>>guess;
    cout<< check (guess, x, letter)<<endl<<endl;
    return 0;
    } //end of main function
    int randomNum(int x, string letter)
    int x = rand()%25;
    cin >> letter [x] >> endl;
    return x;
    string check(string guess, int x, int letter){
    if(guess=x)
    cout << "You win, the letter is "<<x<< endl;
    if(guess>x)
    cout <<"The number is lower than "<<guess<< endl;
    if(guess<x)
    }//end of program
  2. #2 Re: Need some help with C++
    WI
    That is telling you that you cannot use the bool operator ">" in your comparison. You need to try comparing the same kind of variable. You are trying to compare an INT to a STRING. Won't work. That operator is for INT to INT.
  3. #3 Re: Need some help with C++
    Canada
    Ok. Thanks. I will try it out with ints and see if it works.
    Tried it and that narrowed it down to these three errors from 35. lol.
    ap12\ch12appe04 solution\ch12appe04 project\ch12appe04.cpp(27) : error C2440: 'initializing' : cannot convert from 'const char [1]' to 'int'
    1> There is no context in which this conversion is possible
  4. #4 Re: Need some help with C++
    Canada
    Narrowed it down to just the 2679 error now.
  5. #5 Re: Need some help with C++
    WI
    paste your current code up again
  6. #6 Re: Need some help with C++
    Canada
    Ok. Here it is. I still have to figure out how to pass the random number to the letter string and get it to get the appropriate letter.
    //Created/revised by Devan Taylor on February 6th, 2010
    #include <iostream>
    #include <string>
    #include <ctime>
    #include <iomanip>
    #include <stdlib.h>
    using std::cout;
    using std::cin;
    using std::endl;
    using std::string;
    string check (int, int, int);
    randomNum (int, string, int);
    int main()
    //declare variables
    int guess = 0;
    int randomLetter = 0;
    int x = rand();
    cout<<"Number: ";
    cin>>guess;
    cout<< check (guess, x, randomLetter)<<endl<<endl;
    return 0;
    int randomNum(int x, string letter, int randomLetter)
    x = rand()%25;
    cin >> randomLetter [x];
    return x;
    string check(int guess, int x, int letter){
    if(guess=x)
    if(guess>x)
    if(guess<x)
    }//end of program
  7. #7 Re: Need some help with C++
    Canada
    I now have the program running without errors, but it is displaying 41 as the number each time and it will say you are correct when you enter anything. I am going to change the if(guess=x) and such to if(guess>26||guess=x), if (guess<26||guess<x) and if(guess=26||guess !=x) or equivalent. I am trying to have this done tonight because I work 9-5:30 tomorrow and it is due tomorrow night.
  8. #8 Re: Need some help with C++
    WI
    Quote Originally Posted by bronzemist02 View Post
    the '=' is not a comparison operator... Can't believe I missed that.
    '==' is the comparison operator.
    What you are doing with this piece of code:
    Code:
    if(guess=x)
    is actually setting guess equal to x. So it always returns true.
    To compare you use ==. ie:
    Code:
    if(guess==x)
  9. #9 Re: Need some help with C++
    WI
    Here, this is all the logic to guess numbers. I was bored. REALLY bored, and decided to re-write parts of this etc.
    What exactly is the assignment? I see you have an alphabet.. are they supposed to guess a letter? The logic is the same, but you need to learn how to use strcmp with char[]'s.. It's easy and fast.
    your functions are unnecessary in a program this small. If you decide to keep them, they need editing. You don't even use your random function inside of main at all.....
    Otherwise this has everything you need. just fill in your blanks.
    Code:
    * I'm bored.. so i played around some
    * to change this to guessing letters.. it would be easy
    * no need for stupid strings just fill a char array how i did
    * and use char[]'s instead of ints. Then use strcmp().
    * http://www.cplusplus.com/reference/clibrary/cstring/strcmp/
    * I'm assuming your assignment was to do it with an alphabet.. Hence me doing the numbers so you can see
    * the logic. You can figure out the rest on your own.
    * This compiles just fine on the GNU Compiler running on Debian Linux.
    * Real programmers use some kind of POSIX system.. :)
    #include <iostream>
    #include <ctime>
    #include <iomanip>
    #include <stdlib.h>
    int main()
    //declare variables
    // WHY HAVE AN ALPHABET?? I DONT KNOW!! You had one!
    char alphabet[26] = {'a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v$
    int guess = 0;                  // the number we are guessing
    int randomLetter = 0;           // the randomletter (it's a type int???) I'd rename to just 'random'
    int x;                          // why declare this and set as rand()? Waste of time.
    // create our random number
    srand((unsigned)time(NULL));    // you need use srand before rand.. (look it up! Seeds the generator)
    x=rand()%25;                    // keeps us under 25
    // while they haven't quit.. or guessed right.... WE MAKE THEM PLAY!
    while(1)
     cout<<"Guess a number (0 to quit!): ";
     cin >> guess;
     if (guess==0)
            cout << "\n\nThanks for playing!" << endl << endl;
            break;
     cout << "YOUR GUESS WAS: " << guess << endl << endl;
     // debug
    // cout << "THE RANDOM NUMBER WAS: " << x << endl << endl;
     // we decide if guess = x.
     if(guess==x)
            cout << "\n\nYou win!!!!!\n\nThe number was " << x << endl;
            break;
     if(guess>x)
            cout <<"The number was lower than " << guess << endl;
     if(guess<x)
            cout <<"The number was higher than " << guess << endl;
    } // end of while
    } // end of main
  10. #10 Re: Need some help with C++
    Canada
    Thanks a lot. Yes. The project is to get the user to guess a letter. I'll try it and see if I can get it working with strcmp and the char arrays.
  11. #11 Re: Need some help with C++
  12. #12 Re: Need some help with C++
    Canada
    I tried to get it working with strcmp and char arrays and it wouldn't let me compare the two arrays because the letters one had a value of [26].
  13. #13 Re: Need some help with C++
    WI
    ok
    you compare the guess to alphabet[x]
    and out of curiousity are you in northern or lower ontario?
  14. #14 Re: Need some help with C++
    Canada
    I did set it to that at one point. It wouldn't let me compare the other char to the alphabet one though, that is why I got that error. I'm not in Ontario at all. I'm in P.E.I.
  15. #15 Re: Need some help with C++
    Canada
    I am working on another assignment that gets a user to input an employee code in two parts (letter and number) using two variables. It then opens a file and checks it for the characters entered and displays the proper lines. It has no errors, but it only wants to display the last line in the file. Also, my if statement keeps saying that the p# codes are invalid. I have spent at least 6 hours on this so far and can't get it to work. Any help or suggestions would be greatly appreciated.
    //Ch13AppE02.cpp
    //Displays the names of salespeople having
    //a specific code entered by the user; the codes and
    //names are stored in a sequential access file
    //Created/revised by <your name> on <current date>
    #include <iostream>
    #include <string>
    #include <algorithm>
    #include <fstream>
    using std::cout;
    using std::cin;
    using std::endl;
    using std::string;
    using std::ifstream;
    using std::ios;
    //variable declaration
    void displayCode();
    int main()
    string code= "";
    string codenum= "";
    //Enter a code to be searched
    cout << "Enter an employee code to be searched: "<< endl;
    cin>>code;
    cout << "Enter an employee number code to be searched: "<< endl;
    cin>>codenum;
    //call appropriate function
    //or display an error message
    while (code !="x" && codenum !="x")
    if (code =="p" && codenum =="1"|| code =="p" && codenum =="2")
    displayCode();
    if (code =="f" && codenum =="1"|| code =="f" && codenum =="2")
    displayCode();
    else
    cout<<"You have entered an incorrect code. Please enter f1, f2, p1 or p2." << endl;
    return 0;
    }//end while
    }// end of main function
    void displayCode()
    //reads records from a file
    //and then displays them
    string code= "";
    string codenum= "";
    //open the file
    ifstream inFile;
    inFile.open("namecode.txt", ios::in);
    //determine if the file is open
    if (inFile.is_open())
    //read a record
    inFile >> code>>codenum;
    }//end if
    while (!inFile.eof())
    //read another record
    getline(inFile, code);
    getline(inFile, codenum);
    }//end while
    if (inFile.eof()){
    inFile.close();
    //display the code and code number
    cout << "The code is: " << code <<codenum<< endl;
    }//end of displayCode function
