Thread: pacesetters are way better than SLP's...when running a 4T80-E
Results 1 to 9 of 9
  1. #1 Re: pacesetters are way better than SLP's...when running a 4T80-E
    St. Louis Mo.
    What kind of coasting is that you have your PS's? Or is that just heavy duty black engine paint Just curious.
    James Shafer
    St. Louis MO
  2. #2 Re: pacesetters are way better than SLP's...when running a 4T80-E
    hangover park IL, in the garage working on one of 12 3800's
    Quote Originally Posted by GeddyLee View Post
    no coating (i'd destroy it anyways lol) the protective paint they use will be sand blasted off and re painted with the same alum high temp paint that we used on the 442's LIM/Exhaust (held up damn well except for 4 rust spots from not doing enough surface prep)
    this is of course after both sets get O2 bungs welded into each primary, ported/rewelded (anyone thats seen the weld quality would prob do the same) and a couple tabs for a bolt on Y pipe, and removal of the EGR stovepipe/flange section to clean up the #6 primary flow.
    once we are satisfied with the headers (prob after a year) we'll likely get them ceramakromed to match all the polished aluminum a bit more
    the whippled Riv just needs its primary O2 bungs welded in...dont know if eric will get em coated or not...he prob will...i mean its gonna have a SC snout to TB measurement of over 3 ft
  1. Thinking about running Drag Radials...
    By Iron Indian in forum Tires & Wheels
    Last Post: 03-27-2008, 12:13 AM
  2. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
  3. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
  4. What brand/style of tires are you running?
    By John02Hawk in forum Tires & Wheels
    Last Post: 02-15-2008, 01:18 AM
  5. Rockers and Pacesetters at the same time??
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 09:35 PM
