Thread: Buggy L67
Results 1 to 20 of 24
  1. #1 Buggy L67
    Donating Users GoldGTP's Avatar
    Sacramento, CA
  2. #2 Re: Buggy L67
    Kemmerer, Wyoming
    That's pretty cool
  3. #3 Re: Buggy L67
    I think if I ever did a l67 buggy it would be rear engine and a 5 speed.
  4. #4 Re: Buggy L67
    Jul 2010
    Coquitlam,BC,Canada
    LS motor and fully selectable auto FTW.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Buggy L67
    GXP Level Member
    Mar 2015
    Tomball
    I have actually seen guys use the stock trans and mid mount the engine inline to drive the front and rear ends, pretty neat in a really light crawler. I have a bunch of friends that are really into rock crawling and trail riding and they all have crazy rides.
    Jeff
  6. #6 Re: Buggy L67
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    Jeff
    Are there frame/chassis kits you can buy online? I've always been curious about swapping the engine and transmission out of my car and into a buggy
  7. #7 Re: Buggy L67
    GXP Level Member
    Mar 2015
    Tomball
    I have no idea, all of my friends rigs are scratch built, even the old one from Monster Garage I worked on was sent out to Alabama and the suspension redone. I stripped out all the wiring out of it except the Pro Flo fuel injection and rewired the entire thing and made it street legal. The others all built their own chassis's, I just wired them.
    Jeff
  8. #8 Re: Buggy L67
    Jul 2010
    Coquitlam,BC,Canada
    Same here, most of my friends build from scratch. Lots of makers of frames out there. Better to buy a rig that is built then tweak it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Buggy L67
    GXP Level Member
    Mar 2015
    Tomball
    Yeah the guy that bought the Bronco that was featured in Monster Garage paid a lot for building it, and I didn't charge nearly enough for rewiring it, then he sold it so someone in Ohio for 40K. I thought that was crazy that he could get that much for it, but it had a lot of expensive parts on it and it was freshly redone so I guess that's what a built one will go for.
    Jeff
  10. #10 Re: Buggy L67
    Sacramento, CA
    Here is another 3800 thread for 4x4 rigs
    http://www.pirate4x4.com/forum/gener...800-bible.html
    Pretty neat stuff there...
  11. #11 Re: Buggy L67
    Kemmerer, Wyoming
    probably would be cheaper to swap a 5.3 iron block ls engine into it, because where I live one of those can be had for 600, while the L67 engine is more than 1000
  12. #12 Re: Buggy L67
    Buffalo
    Is all about the low end torque.
  13. #13 Re: Buggy L67
    If that's the case, both would be even if it was a 5.3.
    280 ft/lbs at 3,200rpm and 335 ft/lbs at 4,000, the torque curve on the V8 at 3200 should be equal or slightly higher than 280 already.
    Or slap a 6.0 in there and have 360 ft/lbs at 4,000.
  14. #14 Re: Buggy L67
    Buffalo
    Yeah but isn't a 6 lighter ?
    im not a expert but the articles you guys post here told me these reasons they chose the l67 supercharged
  15. #15 Re: Buggy L67
    Actually they are pretty similar is weight. If you have a aluminum 5.3 it would be a shade lighter, they are 80lbs lighter give or take.
    A iron block 5.3 is roughly 350-375 dressed out, a 3800 is about 300lbs without everything attached. Figure you add some pulleys and what not it's still around 340-350lbs at a guess.
  16. #16 Re: Buggy L67
    Kemmerer, Wyoming
    what did the aluminium block 5.3 get put in?
  17. #17 Re: Buggy L67
    Buffalo
    Hmm. So the supercharger isn't an advantage in a rock crawler ? Lol I have zero knowledge when it comes to those
  18. #18 Re: Buggy L67
    Tons of different vehicles.
    Many early flex fuel silverado/sierra/tahoe/suburban/yukon around 04-06 got them, the trail blazers/ saab 9-7x SUV got them, buick rainer because they are lighter and had DoD/AFM is those suv's. The first year in them didn't though, so 2004 or 2005 I think.
    Past the GEN 3 years, like almost all the trucks started getting aluminum motors. Likely the most common AL block is the LC9 like I have in my truck, the 2010 I owned and my parents 2012. They still made an iron block but I guess it was kinda phased out and was mainly just there for the 6.0 in the work trucks I think.
  19. #19 Re: Buggy L67
    Quote Originally Posted by CrazyGuy03 View Post
    Not really, it's all about gearing in a crawler. So many guys use the 22R 4 banger from toyota just because it's a bullet proof motor. Like 5.xx gears with a double low low transfer case, you could walk faster than it would crawl type of gears.
    If you want to do more trail riding that covers more distance and higher speeds, then you'd want a bigger motor and that's where it would be more helpful. I tuned my old co-workers 5.3 swapped rock crawler because he wanted bigger power and for trail riding and not just climbing things. But when he is ripping it up, the extra torque is really helpful from the V8.
  20. #20 Re: Buggy L67
    Kemmerer, Wyoming
    to use an LC9 with dod/afm, does that stuff have to be deleted in order to make higher amounts of power, and is it just changing the lifters? learn something new everyday, I thought all the truck ls series blocks were made with iron.
  1. SC 3800 Rock Buggy. (Video)
    By The Big Al in forum Off Topic Discussion
    Last Post: 04-13-2015, 06:26 AM
