Thread: Looking for PCM tuner in NJ
Results 1 to 8 of 8
  1. #1 Looking for PCM tuner in NJ
    SE Level Member Blacknitews6's Avatar
    May 2017
    south jersey
    Looking for a dyno tuner in the south jersey area. I don't mind traveling a little.
  2. #2 Re: Looking for PCM tuner in NJ
    Sep 2015
    Cheyenne, WY
    Scotty!
    Your call!!
    You da man!!!
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  3. #3 Re: Looking for PCM tuner in NJ
    i aint got a dyno lol but i could tune ya. they say a street tune is best. and sadly most shops dont know wtf they are doing with a 3800. that would be the very first question, can you and have you tuned many 3800 set ups. most have not.
  4. #4 Re: Looking for PCM tuner in NJ
    May 2017
    south jersey
    Scotty, you tune? That's good to hear. I want to remove the M90 and add a Z7 turbo kit, 60# injectors, ZZP ST1 cam....etc. I know what you mean about street tuning being better. I had a 2002 WS6 A4 with ported heads, a comp. 216/220 cam, and a Vig3600 stall. When LS1-Edit first came out i tuned my WS6 out on RT.42 in Camden County. I got my car to idle without any surge. It was a learning process, but i did run a best time of 11.73@118mph on a 1.78 60ft.
    I still had my stock 10 bolt and stock 3.23 gears. So i took it easy when launching it. I had no weight reduction. No skinnies, and still ran my stock heavy front sway bar. I'm glad i can contact you for my GTP turbo build. I might buy HP Tuner later on, but i never tuned for boost before,so i rather call you sir.
    Can u PM me your number?
  5. #5 Re: Looking for PCM tuner in NJ
    theres really not much difference between a sc and a turbo tune. what year you got? i could send you a pcm with a starter tune, at least it would run right with the new injectors. hell it might be all you need. unless the trims are off and it needs maf tuning. they all ask for something different. no 2 engines are 100% the same.
  6. #6 Re: Looking for PCM tuner in NJ
    May 2017
    south jersey
    It's a 2000 GTP
  7. #7 Re: Looking for PCM tuner in NJ
    you would be in luck, the last pcm i have here took a 2000 gtp bin. its got a turbo tune, 60 lb injectors, overkill trans tune, with shifts at 5800, timing is stock. i can raise it now if you like, or later on when you come for the fine tune part. stock is safe to start with. then add afterwards and see how much it will take.
  8. #8 Re: Looking for PCM tuner in NJ
    Sep 2015
    Cheyenne, WY
    You two should meet up at Rods Olde Irish Tavern in Sea Girt and discuss this.
    http://www.rodstavern.com
  1. 97-03 DHP or HP tuner, off board tuner and top 1/2 L36 parts
    By Scottydoggs in forum For Sale - Parts
    Last Post: 10-25-2018, 07:46 PM
  2. HP Tuner help
    By WACHS in forum PCM Tuning
    Last Post: 06-28-2012, 11:29 PM
  3. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
  4. I think I need a tuner....
    By 01gtspecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 06:18 PM
