Thread: Question... NO
Page 3 of 43 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 844
  1. #41 Re: Question... NO
    Antioch, IL
    Projected 4 wheels back on ground next sunday or sooner. New alternator will be the last thing. After 2 days of stalling on the break lines because I kept scaring myself............... 2 fronts are routed to their locations. Final strapping of the lines will happen when all 4 are done. I love this flaring tool, flaring the copper/nickle line is a joke almost like play dough.
    Cut
    Uploaded with ImageShack.us
    Flare, this is step one bubble flare, step 2 produced the double flare.
    This is how I mounted the flare to the vise and vise to the ground haha. 2 6" bolts inbetween, secure enough for this manly man.
    Walla your double.
    Walla a bubble flare, this goes to the flex line to the calipers.
    The 4 lines going to the abs looked great, so I decided to keep the oem flex line and flared that end into a threaded coupling.
    Flared again into the new line and walla
    Completed front driver side. I did the easy one first
    Have to wait for my SS flex lines to come
    2009 Challenger SRT8
    Expert at being gay.
  2. #42 Re: Question... NO
    nice work, good to see it being done the right way for once.
    lord knows ive used a few compression fittings in my day. lol
  3. #43 Re: Question... NO
    Antioch, IL
    welding done, brake lines done!! paint tmw, maybe bleed lines and gmpp install. shes gotta be running soon!
    not looking forward to cleaning down the inside......
  4. #44 Re: Question... NO
    Dec 2012
    Where 4T65E's were born
    Nice job on the brake lines. That's how I'm gonna do mine, the whole line and unions only.
    Did you re-use the old proportioning valves?
    Sold.
  5. #45 Re: Question... NO
    Antioch, IL
    Yup I reused them. The front of the valve takes a bigger fitting, but the backs take the same as the hardline to caliper flex line. Ill post those sizes eventually.
  6. #46 Re: Question... NO
    Antioch, IL
    going into the valve I think its M12x1.0 bubble thread.
    out of valve and all hard line to flex line is m10x1.0 bubble
    Threaded coupling (union) is a 3/16 line 3/8-24 inverted (double flare aka standard flare)
    nuts that go into union 3/16 3/8-24 inverted
    nicopp line seriously bends like a joke and flares even better. Bought 2 rolls and have maybe 10 feet left. One roll (25ft) will do both fronts and driver rear. passenger rear is one hella length
  7. #47 Re: Question... NO
    Antioch, IL
    Secret recipe
    Little bit of this, little bit of that, dash of that
    Excellent, runny but not to runny
    Brush doesnt fit in the small spaces, pressurized spray paint can will take care of that tmw.
    Gas tank
    Walla oldschool rust preventer/inhibitor.
  8. #48 Re: Question... NO
    Grand Rapids, MI
    still not a fan of that ... but i love what u did with the rockers
  9. #49 Re: Question... NO
    Dec 2012
    It looks a little strange that he used yellow, but hey, who looks under there? If it's effective, it was worth it. I just used standard rubberized undercoating.
    Sold.
  10. #50 Re: Question... NO
    Feb 2013
    37.295091, -121.930053
    my question is are you going to hit the spots you missed via jack stands? once it drys.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #51 Re: Question... NO
    we talked about the finishing, he said he was going to use a airasole can set up to re spray where the brush cant hit. so jack stands spots should be covered.
  12. #52 Re: Question... NO
    Feb 2013
    ok just didnt want to see all that work rot out in a few years
  13. #53 Re: Question... NO
    Antioch, IL
    scott actually listened to me haha.
    I used boiled linseed oil as its natures rust protectant, rustoleum OIL paint ( because linseed oil is.... oil, and for color) and turpentine to thin them. (and dry faster, more you thin the faster is dries) This coating stays "wet" for a few days as to let the linseed oil soak into the rust and metal getting deep down protecting it. Today the finish is sticky and still very transferable, can really smell the linseed oil now.
    Yellow? To me thats the most visual other than white. It will let me gauge how its doing, where it gets thin etc etc. If it ever needs to be applied again all I have to do is mix up a batch and reapply. $25 of supplies and I used about $10 worth, undercoating dont get much cheaper unless you just buy a quart of linseed oil and throw it on.
    GMPP kit is on after 1.5years+ of having it. New alternator and finally replaced the windshield washer pump that never worked when I first bought the car years ago. Tmw exhaust is being thrown on and pending on the weather, wheels may be on the ground. If not then you dam well known sunday its back on the road.
  14. #54 Re: Question... NO
    Cleveland Heights, Ohio, United States
    $750 to do my car, come to Ohio lol. Everybody here likes to cut corners unless im missing someone
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  15. #55 Re: Question... NO
    Antioch, IL
    Tmw attach plastic coverings, struts and wheels back on. Tis a sad day, took so long to finish, but came so fast.
    Its a interesting sound, mellow idle, not at deep as my last setup, but not as loud as I expected. Excited to hear it under load. The blower still screams louder though.
    2.5" from mandrel bends? truebenz? one of those people. I will not tell u the setup.
    4" slant rolled, yes I know the right side is a little higher up, have to think that one.
  16. #56 Re: Question... NO
    Excellent work guy, maybe I should have a lil competition with you and see who had to replace more metal with my 2 door that got t boned.
    Considering I can cut 100% of the **** I need off a wrecked car I got the engine out of. Im thinking of doing it. I scored an IngersollRand 30 gallon compressor too so I might just need a wire feed welder. It will need drivers quarter, rockers and drivers door. Plus the front bumper too. All the parts are sitting in oslo. Would cost me maybe 300 bucks for all the metal, door and front bumper.
    I know the cars going to be on the ground but id have a hell of a time not rattle bombing the whole bottom black that color would drive me nuts.
  17. #57 Re: Question... NO
    Antioch, IL
    thanks 98. I wanna see progress pics when u try to do more metal than me.
    Funny though was that my original plan was rust bullet black underneath, but the linseed oil test was eating me alive then I figured blue to match the car. I saw yellow at the store and laughed and bought it... now its funny
  18. #58 Re: Question... NO
    antioch ill
    im gonna kick the jackstands out from underneath it tomorrow when i drive by
  19. #59 Re: Question... NO
    Antioch, IL
    took it for a test drive, was hearing a noise. Found out the rear ss flex line was hitting the rim ugh. fixed that.
    my passenger window doesnt go down now HAHA, man wtf. Worked great before this, perhaps a fuse somewhere for some unknown reason, driver works great.
  20. #60 Re: Question... NO
    Antioch, IL
    Drove 25 miles, all is good. Kinda scary driving a car thats been on stands for almost a month not knowing if the work done will fail at any given time. I dont think my washer pump works that I just replaced unless it takes a long time to prime/purge or something? Or I dont know the correct button haha. That and why the passenger window dont work, doesnt even make the lights dim holding it down. Oh well.
    Gmpp kit is over rated when you drive normal btw. Good to have anyway
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
