Thread: BrandonHall10's 2001 Regal GS - On Pregens?
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 153
  1. #81 Re: BrandonHall10's 2001 Stripper Regal GS
    PS.. Why bother with smaller pulley etc when we know you want to Gen V it etc.
  2. #82 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    I actually walked away from one in the junkyard yesterday. Not yet...
  3. #83 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Trans cooler is finish mounted. Had to change out the top fitting due to limited real estate. I *think * I have all the fittings I need to plumb it. Running in series, going directly into the top radiator boss with a M18-1.5 o-ring fitting x -6AN and into the trans case with a 1/4"-18 NPS x -6AN.
  4. #84 Re: BrandonHall10's 2001 Stripper Regal GS
    Looks good.. you need it in that heat
  5. #85 Re: BrandonHall10's 2001 Stripper Regal GS
    Kemmerer, Wyoming
    well, when you can get a decently low mileage gen 5 for a hundred bucks off of LKQonline...
  6. #86 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Thanks Bill. Yeah, out running errands yesterday with an air temp of 107°, the trans temp just barely tipped over 200°. I much prefer to keep it under 180°
    Marshal, $100 is about what the local Pull a part gets after all the BS fees. I'll get there someday. Back when I had my GP, you would never see a GENV in the yard. I've seen 2 of them in the last 6 months. They're out there. I'm not worried.
    I'm thinking methanol injection would be my next best bang for the buck, after the headers are on. Best fuel I can get here is 91. Well, there is one E85 station up the road, but that's not super practical for the family vehicle.
  7. #87 Re: BrandonHall10's 2001 Stripper Regal GS
    Kemmerer, Wyoming
    water methanol injection works good, just have to be able to monitor your air fuel ratio and be able to subtract fuel. I put my water methanol tank in the trunk, but you don't have to, just have to make sure you mount the pump at the lowest possible point.
  8. #88 Re: BrandonHall10's 2001 Stripper Regal GS
    When I got my Regal (well the white one) I wanted not white and NA to consider rockers and a turbo. We all know that didn't work out. But I would have liked it.
  9. #89 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Quote Originally Posted by SgtMarshal View Post
    Thanks for the feedback. Long term plans include installing a WB. I'll weld the bung in the headers before I install them so I'm all ready when that time comes.
    So you're saying things don't always go as planned?
  10. #90 Re: BrandonHall10's 2001 Stripper Regal GS
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Ill be doing meth and a WB sooner rather than later, id be happy to share my experience.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  11. #91 Re: BrandonHall10's 2001 Stripper Regal GS
    meth rules. you know if you cant get e85 anyways lol
    i went from a 3.2 on a gen 3, 8.5 psi, at 14º wot. added meth, in 20 minutes time i was on a 2.8 and 21º at 13 psi.
    i set my start to spray at 6 psi, max at 10 psi. if driving normal the meth dont spray. aem kit has a led light to let you know when its on.
  12. #92 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Please do.
    I do have E85 available and not too far from me, but it's the only spot on this side of town. Not very practical for the primary/family vehicle. Especially if we take this thing on a 2-1/2 hour trip up to PHX. There's nothing in between here and there except Indian reservations.
    I had similar results in my GP when I went from 91 to E85. Pulley drops for days. Ran cooler too. I loved everything about it except the availability.
    Noted. Assuming you went with the 30-3300 kit?
    Trans cooler is plumbed. Took the car for a quick rip up the road to bring everything up to temp. No leaks! Haven't done the drive through test, but it looks like it will keep the fluid nice and cool. When I shut the car off the trans was 40 degrees under coolant temp. I may need to partially block it off in the colder months. Time will tell.
    The way it is plumbed, I can easily go back to the stock configuration. I didn't cut or remove any factory hoses. Here's how I did it:
    Trans vertical line / clip in fitting → Bottom of factory radiator cooler / clip in fitting → Top of factory radiator cooler / M18x1.5 O-ring X -6an fitting → Bottom of LPD cooler / -6an X 1/2"npt straight → Top of LPD cooler / 1/2"npt X -6an 90° → trans horizontal line / -6an X 1/4"nps
    I ran both lines to the aux cooler around the left side of the core support. Probably could have saved a little hose if I ran the feed to the aux cooler around the right side but I don't mind the extra fluid capacity and cleaner installation.
    Up next should be the shift kit. Maybe weekend after next.
  13. #93 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Nope. Not shift kit... Fire extinguisher.
    While I can't say that using the OnStar bracket to mount a fire extinguisher is uniquely my idea, I guarantee it would have one regardless. I have not personally had one of my vehicles catch fire, but I have been tangentially affected by vehicle fires more than a couple times. Had a flatbed truck burn down inside a shop I used to work at. Watched a Neon cook in a grocery store parking lot back when I lived in Michigan, and most recently had a friend show me cell phone video of his early 80's Bonneville on fire in the right turn lane on of Speedway.
    I've been told if you catch a vehicle fire quickly, it can be fixed with a fair amount of cleanup, but minimal damage. I hope to never find out, but I'll be ready if that day comes. I don't think it should be mandated for vehicles to have fire extinguishers in them, but I'll always have one.
  14. #94 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Here it is, Sunday night as I type this. Just got back from a long weekend vacation. Our first real road trip with this car. Tucson to Show Low. 432 miles round trip with an elevation change of just under 4000' (2389' in Tucson to 6345' in Show Low). I can't say that everything went flawless, but in the grand scheme of things, I think this old car did pretty well. Fully loaded with 5 passengers and all the "stuff" 5 people would need for a long weekend in a cabin. Trunk was full, we were heavy. Going up and down grades of up to 8° for long stretches. On the way there (uphill), never was the temperature UNDER 100° and for more than a half hour it peaked at 117°. It was hot. I had to pull off one time on the way there to let it cool down. 10 minutes of idle time with the hood up and we were back on the road. That's it. Otherwise, all was well. I have come to a couple conclusions after spending 8 hours behind the wheel of this car...
    1.) Meth injection is a perfectly reasonable modification for a bone stock car, depending on your driving conditions. She was knocking pretty bad on some of those longer uphill grades. I think a chemical intercooler would have been a huge help.
    2.) Without the auxiliary trans cooler, the fluid would be cooked after this trip alone. Even with the cooler, the trans temp would jump up to 210° after a long pull. I can't imagine what it would be with just the radiator cooler.
    3.) The amount of knock you see per pound of boost is directly proportional to engine temperature. Like, the amount of knock at just 3psi with an ECT of 190° vs 210° is HUGE.
    4.) I have an exhaust leak. It sounds terrible. I need to get those headers on soon.
    These are all things I already knew, but after this trip they are very much reaffirmed. Back to work tomorrow.
  15. #95 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Normally I'm not a big stereo guy, but even I can't tolerate a blown speaker. After 20 years the factory right side separated. This is step one of a full system upgrade. Plan is:
    1.) door speakers (done)
    2.) rear speakers
    3.) head unit
    4.) amp + sub woofers
    5.) door tweeters
  16. #96 Re: BrandonHall10's 2001 Stripper Regal GS
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by BrandonHall10 View Post
    2.) rear speakers
    3.) head unit
    5.) door tweeters
    I definitely recomend bypassing the factory amp if you can. Also mounting tweeters in the sale panel sounds much better than the factory location.
    Also be super careful with the rear speaker grills , theyre like gold .
  17. #97 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Quote Originally Posted by 04lss View Post
    I did not know this. Thanks for the heads up.
  18. #98 Re: BrandonHall10's 2001 Stripper Regal GS
    Sep 2014
    Richmond Virginia
    If you have any questions on audio, feel free to PM me, ive done quite a bit to my car in that area.
  19. #99 Re: BrandonHall10's 2001 Stripper Regal GS
    Mar 2014
    Tucson
    Plan on it!
  20. #100 Re: BrandonHall10's 2001 Stripper Regal GS
    when you go after the sub..holler. You can do a nice sub and not use trunk space
  1. Coming back to the forum with a GTP this time
    By Supercharged99 in forum Introductions/Noob Questions
    Last Post: 12-16-2019, 02:19 PM
  2. back after a long time
    By dcmarkley in forum Introductions/Noob Questions
    Last Post: 10-01-2012, 01:40 PM
  3. Hey everyone I am back after a long time
    By 98grandprixgt in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 02:16 AM
  4. Time to bring her back ;)
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 11-29-2010, 10:25 PM
  5. Been a long time....but i'm Back!
    By Bogers04SS in forum Introductions/Noob Questions
    Last Post: 02-03-2010, 05:24 PM
