Thread: EJOUIE"s 2005 Impala
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 98
  1. #1 EJOUIE"s 2005 Impala
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    I finally did it. I traded in the Grand Prix. Had such the love/hate relationship with that car for nearly a decade. 172k and low oil pressure, so time to go.
    ...and I got this.
    Its an 05 LS with just under 80k. All the goodies minus the S/C. Old and new below.
    Really liking the interior upgrade. Having comfy seats, working cupholders, and a heated passenger seat. Car already has the strut tower braces on from the GP and GMPP sway kits are on the way. After those are on then its time to do something about the stereo. Anyone have info on the amp specs?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: EJOUIE"s 2005 Impala
    Needs less fishbowl status.
  3. #3 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    Tint hadn't even crossed my mind til now.... that would really make the red and black look nice.
  4. #4 Re: EJOUIE"s 2005 Impala
    thats clean. turbo? lol
  5. #5 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    No, it has a potential top swap later down the road. Still has the black LIM gasket, and after the LIM hell that the GP put me through I already am fairly prepared for most of the work to accomplish it. Not looking for much over 250whp anyways.
  6. #6 Re: EJOUIE"s 2005 Impala
    Just do bolt-ons.
    Leave it alone.
    Downpipe/Rockers/HV3 plus a tune should wake it up enough to enjoy it a little more without it being loud and annoying or having issues.
    I'm not a fan of top swaps anyways...turbo or nothing on that thing...especially since turbo kits are becoming dirt cheap anymore.
    But it is really clean. Nice pick up.
  7. #7 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    All depends on when the LIM gasket begins to go. If turbo is close, then definitely.
    If not, then a top swap would only be a little more effort.
    Turbo kits are coming down, but topswaps are real cheap and would still meet my power goal.
    Going to hold off on all power mods till then so I can do it all in one go and minimize down time.
    Sent from my SM-G920P using Tapatalk
  8. #8 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    So, if I were to put headers on the car I would probably want the smallest diameter primaries available. The website for the S&S headers on the sticky is outdated. Anyone know if there is a copy cat of that design?
    Thinking that the car may be possibly built for hwy cruising. So MPGs while cruising and power in the mid to high rpm range for passing.
    Or do I just do front, rear plogs, and a downpipe; leaving the turbo option still a possibility?
  9. #9 Re: EJOUIE"s 2005 Impala
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    with plogs all you would need is the rear turbo plog, the crossover and snail, with assorted intake tubing and FMHE, in order to make turbo noises.
    If you went top-swap, you would need headers, unless you go intercooled or E85. Plogs might handle it, but they would still restrict on anything lower than a 3.6-3.4 pulley, thus limiting how far you can go with the build. it also depends on how bad your KR monster is once the top swap is on...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  10. #10 Re: EJOUIE"s 2005 Impala
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I got SD headers, they have smaller primaries, I noticed no loss in power down low.
    If I were to do it all again I would of just got the front plog and 3" downpipe, much easier to install and less.leaks to deal with.
    Rear manifold flows good enough I wouldnt bother with it unless you turbo
    Fiy you have3.05 gear ratio, same as 04+ n/a gp's.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  11. #11 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    I noticed the feel of the 3.05s and I love 'em lol. Car will go from 70mph to 80 with a lot less effort.
    Also, GMPP sway bars just got put on. Front was cracked at both ends and really did need replacing. The steering feels much more responsive and feels much more like the old GP.
    35% tint going on next weekend. No mods queued up beyond that though. Still researching nav radios.
    If the rear flows well, then I probably will do just a front plog, rockers, downpipe build. (Leaving the door open for turbo maybe down the road) Not sure about the hv3. Sure it help the passing lower, but will it hurt the cruising MPGs?
  12. #12 Re: EJOUIE"s 2005 Impala
    Quote Originally Posted by Grimsin View Post
    Not all grand prix's got 3.05's, I would say way more and I mean way more got 3.29's in the NA 3800's. 3.05's seem to mainly be with impala's, other buicks like the century, lesabre, lucurne, lacrosse.
    Quote Originally Posted by EJOUIE View Post
    A HV3 insert won't change MPG, you aren't making it take in anymore air at those speeds or use any more fuel. The insert is to better the flow of air during heavy throttle situations and when needed, otherwise if you drive it the same as a stock vehicle it's going to drive the exact same.
  13. #13 Re: EJOUIE"s 2005 Impala
    St Thomas Ontario
    97-03 gt got 3.29
    04+ got the 3.05, only ones that got 3.29 that was 04+ was the comp g
    When I did my first trans swap that's how I found this all out, was looking for the lowest mileage 3.05 geared trans I could find.
  14. #14 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    Got the tint on yesrerday. 35%. Really pleased with the result. Should help keep the interior in good shape.
  15. #15 Re: EJOUIE"s 2005 Impala
    looks good.
  16. #16 Re: EJOUIE"s 2005 Impala
    St Thomas Ontario
    Car is so friggin SHINEY, makes me want to throw a brick on the gas pedal and watch my car fly off a cliff lol.
  17. #17 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    Thanks! I am hoping to keep it that way.
  18. #18 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    Not the cliff bit though. That would be sad. Your build is being used a good bit as a model for my wish list.
  19. #19 Re: EJOUIE"s 2005 Impala
    Newnan, GA
    Planning/dreaming up build lists on two fronts. Audio and performance.
    Audio:
    Thinking nav unit and backup camera as phase 1.
    Speakers and 4 channel amp as phase 2.
    Powered sub mounted in rear deck as phase 3.
    Performance:
    This car will be a hwy cruiser, not a racekar. Not top swap, maybe turbo.
    HV3
    ER rockers(not on zzps site anymore?)
    Plog
    2.5" downpipe
    2.5" dual exhaust catback (mostly for sound and appearance)
    Shift Kit
    Tune
    FWI.
    Now the intake actually would benefit me because of the hwy speeds correct? How do they do on noise compared to the HAI? I am really liking how quiet the Impala is over the GP.
    Now one may say i should just top swap, but that doesn't meet my build goals. The M90 will not help cruise MPGs. Also it will not be adding as much in the upper rpms which I need for passing.
  20. #20 Re: EJOUIE"s 2005 Impala
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Unsure the benefit. It's not a 3800. My 4.3 Blazer has the airbox gutted. I don't notice any more noise from the intake on that engine.
  1. 2005 Impala LS
    By Grimsin in forum For Sale - Vehicles
    Last Post: 02-09-2015, 05:13 PM
  2. 2002 Impala "SS" build
    By Anthony Smith in forum Members Rides
    Last Post: 08-08-2013, 04:59 PM
  3. 2005 Impala LS vs 2010 Mustang V6
    By Grimsin in forum Track Sessions and Kills
    Last Post: 01-24-2012, 01:13 AM
  4. 2005 Impala SS
    By weaver412 in forum Introductions/Noob Questions
    Last Post: 01-31-2011, 03:00 AM
  5. 2005 Impala 9C1 performance?
    By mr love77 in forum Chevrolet Impala
    Last Post: 07-17-2009, 05:33 PM
