Thread: Fuel pumps for everything! 255lph and 340lph pumps!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
  1. #1 Fuel pumps for everything! 255lph and 340lph pumps!
    Donating Users Tengis's Avatar
    Houston
    To get MOAR performance you need MOAR fuel! Fantastic pricing on 255lph and 340lph fuel pumps for just about every make and model! All pumps come with a 1 year "no questions asked" warranty.
    255lph pumps that fit NON-VENTURI and VENTURI Grand Prixs start at $75 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
    E85 safe while flowing more then a commonly used Walbro 255 - what more could you want??!
    The non-venturi will require modifications to the canister (AS DO ALL NON-VENTURI 255lph PUMP INSTALLS INTO NON-VENTURI CANISTERS). To have a true "oem style" drop in pump then you would have to get ahold of a venturi canister and buy a venturi pump.
    Our NON-VENTURI 340lph pumps start at only $125 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
    This pump is not only priced extremely well but it is also E85 safe while flowing significantly more then your typical Walbro 255 at all pressures. Fits into any canister/tank setup that a typical 255lph kit would fit!
    We also carry 255lph pumps designed for RETURNLESS fuel systems like those found on the newer model Mustangs. Our returnless pump is a direct replacement but also much less expensive alternative to the GT500/Ford GT fuel pumps! These start at $130 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
    If for whatever reason you are interested in getting only a Walbro for your 255lph replacement or are interested in a Deutsche Works 300+lph pump then you are in luck! We are currently in talks with distributors to carry both locally and should have good pricing.
    Email or PM if you are interested in buying a pump.
    All pumps are certified and inspected to the same standards as any OEM replacement pump and have a typical failure rate much lower then the commonly used Walbro 255. We also have access to a large list of fantastically priced OEM replacement pumps that carry a lifetime warranty.
    Here is a flow chart, all flow numbers were provided by RCengineering:
    WE HAVE FUEL PUMPS FOR LITERALLY ALMOST ALL MAKES AND MODELS - ask about a 255lph or OEM replacement pump for your vehicle.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    I bought one of the 255 pumps with venturi outlet. Came with EVERYTHING needed to install this in my 02 canister. Super fast shipping and a wicked good price.
    I never realized how crappy my walbro was untill i installed this pump. My car is running awesome now.
    Highly recommended!
    Thanks man
  3. #3 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Bunnell, FL
    so am i right to assume stock is a venturi and modified system is non?
    how do you go about converting? just removing the evap?
    I'm a Sex Offender
  4. #4 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    I have venturi and non venturi pumps. Venturi pumps are drop in for all venturi canisters.
    Unfortunately the non venturi pumps require slight modification to the canister just like the walbro kits. As far as I know (Ive never seen one) there are no aftermarket pumps out there with the same dual inlets as the stock pump for a direct drop in 255lph pump.
    Satin Purple 97 GTP
  5. #5 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Topeka, KS
    Do you have any write-up's or instructions for adapting a 225lph pump to a stock canister? I need to replace my pump sometime but I've never really messed with those types of things.
    My car's a 99.
  6. #6 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    I will make a write up and post it up as soon as I get the chance.
    If anyone wants to buy a pump and send me their canister then I will mod it for you and take pics and such. I may have a canister here already though that I can do it to.
    Satin Purple 97 GTP
  7. #7 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Topeka, KS
    Sweet! Thanks man!
  8. #8 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    I want one of these pumps but I have no idea wtf any of this stuff means. Wtf is a venturi and this canister your talking about.
  9. #9 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Topeka, KS
    Your fuel pump has a "Canister" it sits in. Venturi is the type of pump. Google Venturi.
  10. #10 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    97 GTP has a venturi pump. It is a direct drop in.
    Satin Purple 97 GTP
  11. #11 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Well if/when my fuel pump goes out I know where to get a new one.
  12. #12 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    utah
    Are the returnless kits direct fit for 04+?
  13. #13 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    I need an 04+ canister to double check fitment in. If anyone wants to send me their canister I can install the pump with pictures and send it back. Im pretty sure its not going to just drop in without any modifications at all.
    Ive sold them to a few people putting them in Mustangs and even a few Grand Prixs that never reported back with fitment issues.
    Satin Purple 97 GTP
  14. #14 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    GT Level Member afallucco's Avatar
    Ohio
    Quote Originally Posted by Tengis View Post
    Just put my 255 in tonight, it fits in fine. The last few start ups I've had to prime the pump but I also have a 1/4 tank right now and I heard even walboros have trouble at or under 1/4 tank. Like I said everything fit in fine without issues, I did get a hesitation when coming out of a large freeway turn but again car had a little under 1/4 tank when it happened.
    I lost your email but wanted to say thanks for saving my ass, my stock fuel pump was pretty much dead.
    Oh yeah, 04 GTP
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
  15. #15 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    utah
    with this ill be ordering here shortly. Glad to hear it fits
  16. #16 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Ohio
    Quote Originally Posted by boostedcompg View Post
    If you have any questions just let me know.
    2004 Grand Prix GTP
  17. #17 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    utah
    Sure will man. Thanx
  18. #18 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    Sweet, sounds good. Sorry it took so long for your pump to get there!
    Satin Purple 97 GTP
  19. #19 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Ohio
    No problem, I will say I was surprised to find the added theft deterrent by the car not starting unless I prime the fuel pump a few times lol.
    2004 Grand Prix GTP
  20. #20 Re: Fuel pumps for everything! 255lph and 340lph pumps!
    Houston
    Coming soon... Ive been working with the manufacturer on testing what I believe to be the first 340lph venturi pump - direct drop in on GM canisters! Basically, for all of you people with venturi pumps this will be the best drop in fuel pump upgrade available.
    Ill be offering these fairly soon once they send me a "gauging interest" batch to see if I can sell them locally (Houston is a huge LSx area) and when we FINALLY get our website up.
    Satin Purple 97 GTP
  1. So many fuel pumps!
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 01:30 PM
  2. 97 gp fuel pumps?
    By bigdog853 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 01:35 PM
  3. Fuel Pumps
    By JayAz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2010, 03:25 AM
  4. Walbro 255lph GSS340 pumps 90.00
    By Rocket468 in forum Group Buys
    Last Post: 12-07-2009, 07:46 PM
