Thread: Normal operating Temp
Results 1 to 6 of 6
  1. #1 Normal operating Temp
    Aug 2015
    Port Hueneme CA
    Hey all,
    I am new here as well, I have a 2001 GTP and was wondering what the temp gauge should show.
    Mine on the highway stays just below the first line and in traffice (stop and go) and high temp days at/around 210.
    Never gets to far past the 210 line but not sure if this is normal as this is the first time I have owned a newer GM.
    Thank you.
  2. #2 Re: Normal operating Temp
    First big line after 160 is roughly 190-195ish, stock thermostat is 195.
    To me it sounds 100% normal.
  3. #3 Re: Normal operating Temp
    Aug 2015
    Port Hueneme CA
    FiveFinger, thanks for the reply and love the name (the band rocks)
  4. #4 Re: Normal operating Temp
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    the fans kick on at about 210 .
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  5. #5 Re: Normal operating Temp
    212-214 and 226 if you wanted to be exact.
  6. #6 Re: Normal operating Temp
    Aug 2015
    Port Hueneme CA
    Well I found that my radiator has a link at the top left side. Not to bad but this might be the reason the temps moves a bit more then I would like.
    When the system pressurizes, it does not have a complete seal and might be getting air in the system.
    Again I do not know if this is the case but I found the link during a 100+ mile drive yesterday.
  1. Normal Trans Operating Temperature
    By chris99gtp in forum General Tech Discussion
    Last Post: 05-04-2015, 12:13 PM
  2. Where do I find normal engine operating data???
    By Badgers4life in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-05-2014, 10:58 AM
  3. 2004 - Normal Operating Temperature?
    By freebird85 in forum General Grand Prix Discussion
    Last Post: 07-28-2013, 07:58 PM
  4. 3800 Normal Operating Temp
    By 08 198 Champ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2012, 10:52 AM
  5. What's normal operating temperature in traffic?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 09:23 AM
