Thread: Will these tips fit 😆
Results 1 to 12 of 12
  1. #1 Will these tips fit 😆
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    http://m.ebay.com/itm/2X-Exhaust-Dua...859?nav=SEARCH
    They've been jumping around from 80-92$ will they just slide over the stock exhaust?
    97-03.
    Thanks
  2. #2 Re: Will these tips fit 😆
    stock pipes in the rear are 2.25". you'll need a pipe expander and a welder.
  3. #3 Re: Will these tips fit 😆
    Hold up there brotatoe chip, stock exhaust after the "Y" is only 1 7/8th. Either way you'll need an adapter/pipe expander and a welder.
  4. #4 Re: Will these tips fit 😆
    SWPA
    I just went out and measured mine. From the muffler exit to the pig snouts is 2.25 OD.
  5. #5 Re: Will these tips fit 😆
    I believe the 97-03 is different.
  6. #6 Re: Will these tips fit 😆
    SWPA
    That's a possibility. The Pig snout is also 8.5" long measured from the top of the snout to the back of it where it is welded to the muffler exit. One would probably want at least a 9.5" OL tip in that case.
  7. #7 Re: Will these tips fit 😆
    SWPA
    I would go with something like this
    http://www.ebay.com/itm/Muffler-Tip-...dd09dc&vxp=mtr
    I'm thinking about ordering them myself since I need a little exhaust work done anyway. The dual 3.5" tips look like they will be a tight fit, but should work, unless someone else has knowledge otherwise.
  8. #8 Re: Will these tips fit 😆
    Jul 2010
    Coquitlam,BC,Canada
    The output on my stock mufflers was 2.25".
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Will these tips fit 😆
    Sep 2015
    Seattle
    Yuck, those do look like 28$ tips... So either way the tips will have to be welded on?
  10. #10 Re: Will these tips fit 😆
    SWPA
    You could clamp them, but I wouldn't do it that way myself.
    There is also these ones, but I don't think 9" OAL is long enough.
    http://www.ebay.com/itm/Pair-2-25-An...e4aa0d&vxp=mtr
    Thinking about it again you probably want at least 10" OAL, or you would end up tucking the tips under the bumper further.
  11. #11 Re: Will these tips fit 😆
  12. #12 Re: Will these tips fit 😆
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. i want new tips!
    By QwikGT in forum Visual/Body Modifications
    Last Post: 04-18-2012, 01:19 AM
  2. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  3. GXP Tips
    By GrandPrixGTP1 in forum Visual/Body Modifications
    Last Post: 09-09-2011, 07:02 PM
  4. what do you think of these tips?
    By rocafella2032 in forum General Tech Discussion
    Last Post: 11-12-2009, 02:57 PM
  5. 04' gt n/a ~ tips please
    By Dboy23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-03-2008, 05:49 PM
