Coolant will boil far above 212, it doesnt matter if the coolant reaches 212 or not. The moisture in the crankcase will boil when the oil gets hot enough, the coolant doesnt matter there. It will take that heat and spread it around and cool off in the rad.
But like said, you'd have to have the PCM programmed to run the fans sooner.
