Thread: How to change temp fans come on
Results 1 to 9 of 9
  1. #1 How to change temp fans come on
    Aug 2015
    ill
    2005 grand prix gtp fans come on at 220 or so have a code reader attached I know this is normal in park from what iv read but on the gauge this just looks hot to me. Read though info I read one guy changed it to 205 for his fans to come on. Any one point me in the right direction on how to do this. Iv read a lot on tuning for my eclipse gsx iv had a long time. pretty new to the gm world.
  2. #2 Re: How to change temp fans come on
    you need your pcm tuned for the lower fan settings.
  3. #3 Re: How to change temp fans come on
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    water boils at 212 degrees ... condensation builds up in your oil. higher temps get rid of the water that's why they have the fans come on then. if not you have watered down oil. if you wanna run cooler then you need to change your oil more often. no more 7500 mile oil intervals.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: How to change temp fans come on
    Coolant will boil far above 212, it doesnt matter if the coolant reaches 212 or not. The moisture in the crankcase will boil when the oil gets hot enough, the coolant doesnt matter there. It will take that heat and spread it around and cool off in the rad.
    But like said, you'd have to have the PCM programmed to run the fans sooner.
  5. #5 Re: How to change temp fans come on
    Aug 2015
    ill
    I change my oil every 5k and im only 1200 into this oil change and do you have to have a hp tunner to tune this kinda of car I read the how to on tuning it but hp tunners are like 500.
  6. #6 Re: How to change temp fans come on
    hp tuner would do the trick, and more. not cheap tho. good thing is it can be used on many cars and new cars too.
  7. #7 Re: How to change temp fans come on
    Aug 2015
    ill
    Don't really need it for my others I use dsmlink for them
    Is that normal for the car to get up to 220 ish in park with no a/c or heat on? just seems high up on the gauge its over 3/4 the way up. Iv got new coolant t stat coolant temp sensor and pig tail iv bleed the air out just to be sure its not something else.
  8. #8 Re: How to change temp fans come on
    yeah, its normal for a 04 up, they fans are set higher then the older years for some reason.
    theres also dhp for just under 300, its free to use after you buy the interface. support ends with 05 with dhp tho. it does cover a lot of w bodys tho.
  9. #9 Re: How to change temp fans come on
    Buffalo
    Funny cause im going backwards and trying to tune my Spyder and need stupid tactrix cables and what not.... Looking at the software vs HPT, I would choose HPT all day or at least a DHP
  1. Autometer Gauges
    By chris99gtp in forum For Sale - Parts
    Last Post: 07-22-2015, 01:03 PM
  2. Change fan turn on temp
    By jpchapman94 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 01:22 AM
  3. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  4. Replies: 0
    Last Post: 06-29-2012, 01:08 AM
  5. no temp gauge or fans
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 06:31 PM
