Thread: Whirring sound when turning steering wheel left or right. 2008 grand prix
Results 1 to 13 of 13
  1. #1 Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    pittsfield ma. 01201
    Could use any input on this issue with my 2008 Grand Prix.Getting a faint whirring sound when I turn the steering wheel left or right only when the car is moving. Power steering fluid is full and new serpentine belt steering is fine. thanks for any help.
  2. #2 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    Did you do anything previous to this whirring sound?
  3. #3 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    No just started one day very faint sound only makes it when the car is moving and you turn the wheel
  4. #4 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    SE Level Member wakkamis's Avatar
    Jun 2013
    elgin
    check power steering fluid.
    Thanks dude, I apparently have trouble reading whole posts.
  5. #5 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    He already said it was full.
    Sounds like the power steering pump to me. some times they make noise. I can hear mine but I have always heard it make a little noise. As long as it's not leaking and it's not squealing I would just use the Audio Volume Modification to make it go away.
    Jeff
  6. #6 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    Thanks guys forgot to mention when I crank up the radio the whirring sound stops.Thanks again for your input
  7. #7 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    Do you know if it was ever replaced? My 97' Park Ave has always had a noisy pump and was taken in a couple of times when it was new to fix it they replaced it and a few months later it would make noise again. My grand parents owned it and got tired of taking it in. I changed the pump a few years ago and lifted the wheels off the ground and cranked it lock to lock then started and did that again, put some more fluid in it waited a few minutes for all the bubbles to dissipate then started it ran it lock to lock again a couple of times until it was quiet. Then about 3 months later it started making a faint noise again. My 05' does it too. It's not very loud but I can hear it. At least it's not as loud as a Ford power steering pump.
    Jeff
  8. #8 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Jan 2014
    AR
    Be sure the steering hoses don't touch anything, they can transmit vibrations. If this is steering pump whine flush fluid first before replacing pump. My whine went away completely after a flush.
  9. #9 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    does the pump whine increase with engine rpm's? does the wheel turn easier in park if you give it some gas?
    thinking the pump is on its way out.
    the loud radio trick will only work till you cant turn the wheel any more lol
  10. #10 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    Only a sissy can't drive the car without power steering. I've had this issue with both pumps I had on my Park Ave. Then again the pump was a reman, so who knows the quality. The GP I drove it home with an empty rack and ps pump so it is probaby damaged then. My Diablo kept getting leaks in the hoses and the steering box so I drove it for about 6 weeks without power steering, you know to teach it a lesson, then I bought a new pump and gearbox. Put the gearbox on then just filled pump back up and went through getting the air out and never ended up replacing the pump. It's still on that car to this day lol. I fully expected it to not work but it did. I was pretty young when I did that.
    Jeff
  11. #11 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    Thanks Jeff
  12. #12 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    It is the same sound no matter what I do.Looks like a pump change down the road or radio change what ever quits first. Thanks Scottydoggs
  13. #13 Re: Whirring sound when turning steering wheel left or right. 2008 grand prix
    Nov 2013
    Thanks will check it out
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  3. Popping sound only while turning left.
    By CapnBreakAlot in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2013, 09:21 PM
  4. creaking in steering wheel when turning left
    By jbyrne in forum General Grand Prix Discussion
    Last Post: 02-16-2013, 11:00 PM
  5. Squeaking sound when turning steering wheel
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 01-08-2013, 08:50 PM
