Thread: Need some serious help before i damage my car.
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 144
  1. #41 Re: Need some serious help before i damage my car.
    Quote Originally Posted by HighOctaneRacing View Post
    Lol thanks!
    Sent from my LG G3
    Felt right!
  2. #42 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    I would imagine that at high speed the fans would be considerably louder than the regular fans are? I can't even hear when my fans come on low speed (exhaust drowns everything out), usually the only way I can tell is if I have my hand out the window I can feel the hotter air rising up from under the car in traffic or when I have the app on I have it set to flash the display once the temp reaches 215. If I am running the AC it stays on and the temp never rises above about 206. I am sure that at some speed the PCM shuts off the fans as there is enough airflow to cool the system, I would think about 45 or so?
    Jeff
  3. #43 Re: Need some serious help before i damage my car.
    The do turn off, I think it's around 35-45 like you mention.
  4. #44 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    OP what are your findings?
  5. #45 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    T-stat has been doing great and no codes once i flushed the coolant and filled radiator/overflow up.
    I am keeping fingers crossed that the problem is fixed, i should probably replace the t-stat to get an accurate reading of temp?
  6. #46 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    No the thermostat is a mechanical device it usually either works or doesn't. It sounds as though you had air in the system, it wouldn't hurt to change the thermostat, but we were thinking that your gauge must have been off for whatever reason. If you are staying in the middle of the gauge now and aren't experiencing any more issues then it sounds like the problem was solved. FYI we also had a guy on here recently that had his condenser plugged with debris and caused him to run hot.
    Regards,
    Jeff
  7. #47 Re: Need some serious help before i damage my car.
    Buffalo
    Also wouldnt be a bad idea to check that harness like I pointed out. It craps out and the high fan doesn't work
  8. #48 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Thank you for the fast reply's.
    Currently it is staying either, barely under, on and barely over the center tick after the flush/refill of 50/50 coolant/water.
    I greatly appreciate all the help that was given to solve this problem.
    Have a fantastic day everyone.
  9. #49 Re: Need some serious help before i damage my car.
    sounds like its better now. the gp dash temp gauge is not accurate really, they tend to run 2 or 3 lines from the red zone.
  10. #50 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Hello again everyone.
    I have unfortunate news as after i did a flush of the coolant and re-filled everything was butter smooth for about a month. She is over heating again, or appears to be with the t-stat. I park in the same spot everyday and there is never any coolant on the ground, no oil, nothing. I am so confused right now. WHERE IS ALL THE COOLANT GOING? Any advice is much appreciated, thank you.
  11. #51 Re: Need some serious help before i damage my car.
    Buffalo
    It's empty ?
  12. #52 Re: Need some serious help before i damage my car.
    it could be blowing it out the tail pipes. aka head gasket, as rare as it is, it does happen.
    top off the rad, then get out on the road with a some one following you, tell them to look for white smoke out the pipes when you jump on it. if so its steam. aka coolant.
    you can also do a compression test of all cylinders, if one is way lower then the rest, theres your head gasket failure.
  13. #53 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    It is not Empty, but it appears to be lower than before. Well, the overflow jug is below the line now.
  14. #54 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    I will give this a try later this evening
  15. #55 Re: Need some serious help before i damage my car.
    how low? like 2 inches? it may of had a air bubble, and it bled out on its own and just needs to be topped off a bit.
  16. #56 Re: Need some serious help before i damage my car.
    Buffalo
    Did you ever check while its over heating both fans are operating?
  17. #57 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Well, I have tried topping it off a few days ago. Was fine for about until now. It's really confusing me.
  18. #58 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Fans are operational i believe, i will check again today after work.
  19. #59 Re: Need some serious help before i damage my car.
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I would flush the coolant, and put new t stat on, and if coolant elbows are black, replace with the metal ones.
    Thats what I would do, 100$ max for cost, problem fixed?
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  20. #60 Re: Need some serious help before i damage my car.
    Buffalo
    Just saying. I chased a similar issue and it was the wire harness connector. High fan wouldn't always come on when it should. 2 other guys checked and sure enough we all had a crispy connector
  1. Gen v damage
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-12-2013, 08:00 AM
  2. frame damage?
    By SDgrandprixGT in forum Off Topic Discussion
    Last Post: 09-14-2012, 01:19 AM
  3. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
