Thread: Need help identifying a wire
Results 1 to 6 of 6
  1. #1 Need help identifying a wire
    Jul 2015
    IN
    Need some help identifying this brown with a black stripe wire coming outa the harness and running along the valve cover and then it's capped off , thanks .
  2. #2 Re: Need help identifying a wire
    Jul 2015
    IN
  3. #3 Re: Need help identifying a wire
    Jul 2015
    IN
  4. #4 Re: Need help identifying a wire
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'm not sure which it is, but out of curiosity, why do you need to know?
  5. #5 Re: Need help identifying a wire
    Oct 2011
    Toledo, OH
    Best I can tell from searching is that it's a ground wire for something.
    7"
  6. #6 Re: Need help identifying a wire
    Apr 2015
    Quote Originally Posted by industrialfish View Post
    That was my thought, after thinking of it for a bit.
  1. Help identifying connector.
    By EastBayGPSE in forum General Tech Discussion
    Last Post: 02-23-2014, 07:18 PM
  2. Need help identifying part
    By hotshot26 in forum General Tech Discussion
    Last Post: 02-14-2012, 05:32 AM
  3. Need Help Identifying These Rims
    By nawarkk in forum Tires & Wheels
    Last Post: 11-29-2010, 04:05 PM
  4. Help identifying a part
    By RSTraveler in forum Introductions/Noob Questions
    Last Post: 10-18-2010, 02:43 PM
  5. Identifying a 4T65E-HD?
    By 2M8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2008, 07:56 AM
