Thread: 05' GTP Where should my temp grade read
Results 1 to 8 of 8
Brich 05' GTP Where should my temp... 06-27-2015, 01:35 PM
Scottydoggs Re: 05' GTP Where should my... 06-27-2015, 01:50 PM
Brich Re: 05' GTP Where should my... 06-27-2015, 03:52 PM
Fivefingerdeathpunch Re: 05' GTP Where should my... 06-27-2015, 02:02 PM
Brich Re: 05' GTP Where should my... 06-27-2015, 03:54 PM
Fivefingerdeathpunch Re: 05' GTP Where should my... 06-27-2015, 03:59 PM
Scottydoggs Re: 05' GTP Where should my... 06-27-2015, 04:02 PM
J57ltr Re: 05' GTP Where should my... 06-27-2015, 04:07 PM
  1. #1 05' GTP Where should my temp grade read
    Jun 2015
    New Jersey
    I have recently had some overheating problems. Radiator was completely gunned so I had to flush it. Doing so cause some leaks I have fixed. I have cleaned it out, refilled, filled overflow to the line on the bottom, held a few times at operating temp with heat on. My gauge has no numbers just lines. It is getting north of the big line a little over the middle. Feels like it is too hot to me. Not in the red, but only like 3 or 4 ticks away. Anyone have a picture of where in the lines it should hover at operating temperature? I also see people say to top off overflow? Should I have the overflow filled over that line on the bottom?? Thanks is advance for any help.
  2. #2 Re: 05' GTP Where should my temp grade read
    best to get a toque app and read the temp from there. the stock gauge sucks its always up close to the red in the gp's.
    if your seeing 212 thats normal reading from a app or scanner.
  3. #3 Re: 05' GTP Where should my temp grade read
    Jun 2015
    New Jersey
    Where might I get one of these apps?
  4. #4 Re: 05' GTP Where should my temp grade read
    Bleed the cooling system of air yet?
  5. #5 Re: 05' GTP Where should my temp grade read
    Jun 2015
    New Jersey
    Quote Originally Posted by Brich View Post
    Yes. I bled it a few times. I feel like I got all the air out. You bleed it with it running at temp and the heat on, correct? Also, not sure if this means anything, but when the car is off and cool my top radiator hose seems to be compressed. Is that normal? Or a clue I have something wrong?
  6. #6 Re: 05' GTP Where should my temp grade read
    It doesnt matter if the heat is on or not, the heater core always have coolant flowing through it.
    If the rad hose is compressed/sucked in, a bad radiator cap can be to blame.
  7. #7 Re: 05' GTP Where should my temp grade read
    you need a droid phone or tablet with Bluetooth, then a elm327 blue tooth obd2 scanner.
    the app is 5 bucks at the google play store. and the scanner part is like 15 on ebay. http://www.ebay.com/itm/ELM327-Advan...item27d2a7cd42 this one is super cheap.
  8. #8 Re: 05' GTP Where should my temp grade read
    GXP Level Member
    Mar 2015
    Tomball
    The middle line on the 05' is about 195 a needle width above is 200 and 3 needle widths is about 212, 221 comes in just before the next line.
    Edit: I use the Torque pro app and a BAFX adapter. I bought an eBay one that didn't work but it was a different one than Scotty mentioned.
    Jeff
  1. Rocker Arm Bolt size and grade
    By TEK310 in forum General Tech Discussion
    Last Post: 01-01-2014, 02:29 PM
  2. 12 rotor up grade
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2009, 05:32 PM
  3. up grade my injectors ?
    Last Post: 08-31-2008, 03:45 AM
  4. Running higher grade fuel.
    By Dohner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2008, 09:42 PM
