Thread: Noob help.
Results 1 to 7 of 7
  1. #1 Noob help.
    Jun 2015
    Hello fellow Pontiac owners. I was a big import guy before owning a 2006 Grand Prix. I am trying to find a place that sells lowering springs with at least a 3" drop. I cannot find anything anywhere and it's getting pretty frustrating. Someone please take my money.
    Thanks in advance.
  2. #2 Re: Noob help.
    Nov 2013
    Wisconsin!
    Coilovers. Endthread
  3. #3 Re: Noob help.
    No company makes springs that drop that much.
    1.5-1.8in drop is the maximum drop you'll find with springs. Like the above post, only coilovers will drop the car that low.
    And you'll want motor mount spacers if you drop that low and even then, at a 3in drop that is still so low that you will likely get axle vibrations. 2in drop is good enough to take away all wheel gap.
  4. #4 Re: Noob help.
    Jun 2015
    Where would I find springs with a 1.8in drop? Thanks for the info on everything
  5. #5 Re: Noob help.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by sshawnr View Post
    DNA front springs will drop that low at least. Rear spring will need a coil cut to do the same. And they are pretty stiff springs too.
    7"
  6. #6 Re: Noob help.
    Nov 2013
    Wisconsin!
    Zzp...Any wbody site will have something.
  7. #7 Re: Noob help.
    SSC springs or canuck motor sports springs (same people) sell lowering springs with a 1.5-1.8in drop.
    Give it time to fully settle is the key, you never get the full drop right away.
  1. noob to cars but looking to not be a noob :)
    By duditz in forum Introductions/Noob Questions
    Last Post: 09-06-2014, 10:05 PM
  2. gtp noob
    By 04gpgtp in forum Introductions/Noob Questions
    Last Post: 03-01-2011, 11:29 PM
  3. noob
    By rcam81 in forum Introductions/Noob Questions
    Last Post: 01-14-2011, 07:57 PM
  4. Hello from another NOOB!
    By Joey05GXP in forum Introductions/Noob Questions
    Last Post: 12-17-2010, 01:25 PM
  5. Noob here
    By The Absolute in forum Introductions/Noob Questions
    Last Post: 04-29-2010, 12:17 AM
