So a while back I picked up stage 3 zzp heads with 105s on them.
I wanted to run 130s and removed the springs and retainers.
Knowing how I did my spring swap on my stock heads, I figured this would be straight forward.
Its not.
I see shims under the springs in the spring seats - so I removed them
The intake valves are a bit shorter then the exhaust valves - ??
And
the zzp site says to use stock retainers with the "longer ls style valves" - I have those
soo :scratch head: what the heck.... What should I do from here ?
