Thread: OEM #- P0455 help !! 05 GXP
Results 1 to 11 of 11
  1. #1 OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    Got out the code # P0455 coming up, gas cap is on good, maybe need new one? Seems like it fits fine, well anyone have any suggestions let me know! I appreciate the help
  2. #2 Re: OEM #- P0455 help !! 05 GXP
    a lot of the time its the purge solenoid.
  3. #3 Re: OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    How do I fix ?
  4. #4 Re: OEM #- P0455 help !! 05 GXP
    Buy a new sensor
  5. #5 Re: OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    changed the sensor, new gas cap, is my next move a smoke test?
  6. #6 Re: OEM #- P0455 help !! 05 GXP
    i had the same code. i have a tuner so i just deleted the evap.
    but what i found when i changed my fuel pump was likely the cause of my code. if you look under the car under the gas filler door, follow the two pipes down, one is the fill tube, the little one is the vent, my little tube was rotted through and fell off hanging by a rubber hose.
    it rusted through where the tab is welded to the tubes for a bolting location. i cut the line over tab, then used a rubber hose to reconnect the two ends. its a free check and you next step is to look for a busted line, smoke test will show any leaks as well.
  7. #7 Re: OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    Thanks, I'm a rookie, any way you have pics or more step by step haha
  8. #8 Re: OEM #- P0455 help !! 05 GXP
    no pics of that repair. hacksaw and some rubber hose and 2 clamps is all thats involved. if your line is rusted through.
    smoke test will show the leak if you have a smoker to test with.
  9. #9 Re: OEM #- P0455 help !! 05 GXP
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    on my 2000 3.1 the solenoid had a hair line crack on one of the nipples where a hose went on
  10. #10 Re: OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    ok ill have to take it somewhere for smoke test
  11. #11 Re: OEM #- P0455 help !! 05 GXP
    Oct 2014
    Cle
    did smoke test, found front solenoid was broke, was stuck open, fixed it, $380 fix.... and now my heater is broke....
  1. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  2. Check Engine code P0499 and P0455 P0455p
    By itzharrison in forum General Grand Prix Discussion
    Last Post: 09-08-2014, 10:49 AM
  3. Updated: P0455 - EGR Self-Delete?
    By SlowNA06 in forum General Tech Discussion
    Last Post: 12-14-2010, 12:49 PM
